7.24.3 [stable] is released!
Did you just pull 7.24.3, Mikrotik?
Version 7.24.3 just started appearing both as "stable" and "testing" (!) at Mikrotik download site and RouterOS own update only detects 7.42.2 as latest available.
Something is going on.
I just received version 7.24.2, but it has already automatically updated to 7.24.3, resulting in a download-update-fail loop......
Yeah.. i just clicked on "Check For Updates" and the latest version if "7.24.2" for stable, and "7.23.5" for long term. Would appreciate if Mikrotik could indicate if this is a glitch, or is something else going on? I now have devices running on 7.24.3, and some on 7.24.2. Do I rollback?
Look in announcements.
Warning about LTE firmware issue is there but no announcement about firmware 7.24.3 being pulled.
I think we can read between the lines and assume that LTE firmware issue has caused RouterOS 7.24.3 being pulled from distribution?
The system used to "check for updates" does not have the capability to offer different versions to different devices, so to prevent all LTE devices going offline when users are eager to update or have some auto update script, they have set the newest version back to the previous for now. It has not been pulled from distribution, you can still download it from the website.
Yes, other devices are not impacted. This issue is only targeting these specific devices.
Update to my post above.
Offload is back on 7.24.3, but only with a specific ordering. On
7.24.1/7.24.2 I removed the VXLAN port from the bridge and then toggled
l3-hw-offloading (and rebooted) - no effect, ever. On 7.24.3 I disabled
l3-hw-offloading first, then removed the VXLAN port from the bridge, then
re-enabled l3-hw-offloading - offload came back immediately and has stayed.
Same two actions, just the other way round.
Also hit what looks like a separate bug while trying the new "VLAN
interface directly on Ethernet" feature for the transit VLAN. With the
transit VLAN on the port instead of the bridge, hosts behind /32 routes
pointing at a bridge VLAN went unreachable from outside - the router
itself pings them fine, but nothing from outside arrives and torch on that
VLAN shows nothing coming in. A BGP session to a downstream on the same
segment would not stay up either. A plain L2-bridged VLAN on the same box
was unaffected the whole time. l3-hw-offloading=no fixes it within
seconds, enabling it breaks it again. Moved the transit VLAN back into the
bridge.
So: routing from a port-VLAN into a bridge-VLAN looks broken on this chip
in 7.24.3. Anyone else?
Version 7.24.4 has been released:
Hello , i have lost a wireguard conection whith LHG LTE6, after automatic upgrade tinight!
:face_vomiting: :face_vomiting: :face_vomiting:
I hope you delete that stupid scheduler now...
It could be related...
I think, yes i delete, but i have 40+ devices :wink:
So ?
I did 118 manually 2 weeks ago when all the CVE oanuc started ( all sorts of devices).
Didn't take me that long.
I observe worse stability! Random "HoldTimer expired" messages and subsequent re-connections.
