[7.25.2] Originate Default does not work
I have diamond topology pfSense as routing firewall connected to 2 x RB5009 and L3 is done via eBGP, those 2 RB5009 are connected to wifi, switches and L3 is done via OSPF. The Originate Default stopped working after upgrade from 7.25.1 to 7.25.2, tested both "if installed" and "always", all filters removed, even redistribute BGP did not work.
I can confirm the same issue after upgrading to 7.25.2 (originate-default=if-installed). Everything worked fine across previous versions, and the default route only started propagating again after I disabled the out-filter-chain
Add this if (dst in 0.0.0.0/0 && dst-len in 0) { accept; }into filter to workaround this, not great, not terrible.
Thank you! I used a similar rule and it worked for me too.
