Unbelievable, the MikroTik God really exists !! Welcome in industry standard, now we wait for ZBF model (Zone-based Firewall)
*) ipsec - add XFRM interface support;
Lol, wait for the 7.25beta3 announcement topic. ![]()
can anyone tell me how to use it?
Testing Now!
*) wifi-qcom - fix disconnects during fast transition roaming;
@infabo Nope, moved back to 7.23.4 for stability.
0 A interface=wifi1 uptime=2h39m35s signal=-66 band=5ghz-ax auth-type=ft-wpa3-psk tx-rate=6.0Mbps rx-rate=6.0Mbps mac-address=0A:22
1 A interface=wifi1 uptime=2h39m34s signal=-56 band=5ghz-ax auth-type=ft-wpa3-psk tx-rate=960.8Mbps rx-rate=960.8Mbps mac-address=A0:80
2 A interface=wifi4 uptime=2h39m32s signal=-75 band=2ghz-n auth-type=wpa2-psk tx-rate=72.2Mbps rx-rate=39.0Mbps mac-address=C0:5D
3 A interface=wifi1 uptime=2h39m27s signal=-55 band=5ghz-ax auth-type=ft-wpa3-psk tx-rate=6.0Mbps rx-rate=6.0Mbps mac-address=C2:1B
4 A interface=wifi2 uptime=2h36m28s signal=-57 band=2ghz-n auth-type=wpa2-psk tx-rate=144.0Mbps rx-rate=130.0Mbps mac-address=84:2A
