The first part of the IQN is configured on/provided by the NAS itself; the name of the share you created comes after the colon. The slot is the name you want the router to assign that particular disk.
Once it’s connected, it looks like this (mine was 128GB):
[admin@lab-hap-ax3] /disk> print
Flags: B - BLOCK-DEVICE; M, F - FORMATTING
Columns: SLOT, MODEL, SERIAL, INTERFACE, SIZE, FREE, FS, RAID-MASTER, ISCSI-STATE
# SLOT MODEL SERIAL INTERFA SIZE FREE FS RAID ISCSI-STA
0 M nfs1 nfs://192.168.xx.xx/pcie1-sata1-part1 network 235 152 605 184 235 006 853 120 nfs none
1 BM rose-iscsi iSCSI Disk 0050569aa261004 network 137 438 969 856 134 145 351 680 ext4 none connected
This router now has an NFS share from the CCR2116 and the iSCSI share from the TrueNAS box.
Since it’s block level, unless it’s already been formatted, you’ll have to format it once connected.
please make ROS compatible with Hikvision cameras, NOTHING is working…not ROS 7.7 with old SAMBA v1 not even ROS 7.8 with rose is not working NFS either,I just tried,milions peple are using Hikvision cameras…
None – great work here. You’ve given a whole new life to the RB1100s we have. Just the RAID options alone is super useful. And y’all have multiple protocol for containers to use a remote disk…
So perhaps better docs on what you have help more . e.g. “F1” at CLI on ROSE doesn’t have command descriptions:
[user@mt] /disk> /console/inspect request=syntax path=disk
Columns: TYPE, SYMBOL, SYMBOL-TYPE, NESTED, NONORM, TEXT
TYPE SYMBOL SYMBOL-TYPE NESTED NONORM TEXT
syntax collection 0 yes
syntax .. explanation 1 no go up to root
syntax add explanation 1 no Create a new item
syntax comment explanation 1 no Set comment for items
syntax copy explanation 1 no
syntax disable explanation 1 no Disable items
syntax edit explanation 1 no
syntax eject-drive explanation 1 no
syntax enable explanation 1 no Enable items
syntax export explanation 1 no Print or save an export script that can be used to restore configuration
syntax find explanation 1 no Find items by value
syntax format-drive explanation 1 no
syntax get explanation 1 no Gets value of item's property
syntax monitor-traffic explanation 1 no
syntax nvme-discover explanation 1 no
syntax print explanation 1 no Print values of item properties
syntax raid-scrub explanation 1 no
syntax remove explanation 1 no Remove item
syntax reset explanation 1 no
syntax reset-counters explanation 1 no
syntax set explanation 1 no Change item properties
syntax unset explanation 1 no
[user@mt] /disk> /console/inspect request=syntax path=disk,set
syntax <numbers> explanation 1 no List of item numbers
syntax comment explanation 1 no Short description of the item
syntax crypted-backend explanation 1 no
syntax disabled explanation 1 no Defines whether item is ignored or used
syntax encryption-key explanation 1 no
syntax iscsi-address explanation 1 no
syntax iscsi-export explanation 1 no
syntax iscsi-iqn explanation 1 no
syntax iscsi-port explanation 1 no
syntax nfs-address explanation 1 no
syntax nfs-export explanation 1 no
syntax nfs-share explanation 1 no
syntax nvme-tcp-address explanation 1 no
syntax nvme-tcp-export explanation 1 no
syntax nvme-tcp-name explanation 1 no
syntax nvme-tcp-port explanation 1 no
syntax parent explanation 1 no
syntax partition-offset explanation 1 no
syntax partition-size explanation 1 no
syntax raid-chunk-size explanation 1 no
syntax raid-device-count explanation 1 no
syntax raid-master explanation 1 no
syntax raid-max-component-size explanation 1 no
syntax raid-member-failed explanation 1 no
syntax raid-role explanation 1 no
syntax raid-type explanation 1 no
syntax ramdisk-size explanation 1 no
syntax self-encryption-password explanation 1 no
syntax slot explanation 1 no
syntax smb-address explanation 1 no
syntax smb-export explanation 1 no
syntax smb-password explanation 1 no
syntax smb-share explanation 1 no
syntax smb-user explanation 1 no
syntax tmpfs-max-size explanation 1 no
syntax type explanation 1 no
Can it only sync between path and network? Real rsync can also sync between two pathnames, so I tried:
/file/sync/add local-path=/ramdisk remote-path=/nfs
(I have a ramdisk and nfs mount configured)
hoping that it would sync everything I put in ramdisk to the nfs-mounted filesystem, but it does not work.
Also, what can I expect when mountpoints are crossed? When I sync / will it also sync the ramdisk and nfs mounts? (it should not)
One use case I’m picturing is a router with a large NVMe/MSATA store serving small partitions to end-user routers for containers like Pi Hole and Uptime Kuma, to avoid tons of USB sticks out in the field.
To make that happen, the following would be useful (in order of priority):
The ability to create multiple partitions (and subsequently unique shares for individual remote devices)
Basic NFS “/etc/exports” support (i.e. define shares and restrict per-share access by IP address, subnet, etc.)
Authentication for outgoing SMB shares (tied to on-router users or RADIUS would be nice) [does this eventually replace stock SMB server?]
CHAP authentication for iSCSI (not very resilient over a WAN, but less susceptible to permissions problems, unlike NFS & SMB)
I do recognize that some of this could easily be done from within a container (specifically a custom SMB server with a GUI).
do you know any SAMBA server which has web UI and is working in ROS container? I have bought hap AX3 but Hikvision cameras are not able to connect anything from Mirotik. With the cameras is not working SAMBA v1 in ROS 7.7 not even NFS from ROS 7.8 - rose storage is not working.
I haven’t found (or really looked for) any pre-built Samba servers. I built my own using alpine linux and adding the samba package, then created a custom config file. That would be a quick way to do it. But if you have more granular or detailed authentication requirements, you’d have to keep looking or build your own.
It would be nice to have one massive underlying volume to take advantage of RAID benefits, then carve it out for sharing via the different technologies, i.e. one or two larger volumes for file shares (NFS/SMB), and a number of smaller volumes for block shares (iSCSI, nVMEof). You could do this with partitions, but then the partition sizes are fixed. With dynamic volume sizing, we could make better use of the backing store.
Two ways I can see implementing this:
LVM - probably easiest
ZFS - probably more complicated
With LVM, LV’s could be formatted locally and shared (NFS/SMB), or LV’s could become target LUNs for iSCSI/NVMEof.
With ZFS, datasets would be used for shared volumes, and ZVOLs for remote LUNs.
Yeah, both BTRFS and ZFS are great choices but as the latter is a third party add-on (originated from Sun Microsystems) it would likely be harder to maintain.
likely ? Look at for example the ZeroTier package ; MT released it at version 1.6.6 and it was never updated since then … ZT is already at 1.10.x
Same with Wireguard.
If you cannot commit to maintain it, leave it!
I do understand what you mean. However, I tried to emphasize that a standard built-in kernel module like Wireguard is for obvious reasons much easier to maintain than a third party add-on like ZeroTier that requires much more work as part of the porting process. The same goes for ZFS.
