How about just an “ln -s” or some kinda “alias”? For example, I’d still like to have some /disk1 (or whaterver) - just be an symlink/alias to the busX-partY scheme.
The underlying issue is that ROSE client can pick the mount name, so less of an issue there. But if the same script runs on a ROSE server, the path isn’t the same without mucking with the slot= names, which sometimes requires reformatting. And I do actually like the busX-partY scheme, just want to make an well-known alias for the “default disk”.
Maybe one of the protocols act like a loopback for the same device (e.g. it’s a client and server) to essential achieve the same result? But seems overkill when the analog of “ln -s” is really what I’m looking for.
Anyone using a Synology NAS and was able to mount a NFS-export onto a Mikrotik ? (I'm using RB3011-ARM here to test)
It just won't work, getting "Protocol Not Supported" error ?
(while I use the Synology with a bunch of mounts to other systems here, media-players etc. In-house I only do NFS)
I created a new file-share specific for this.
Flags: B - BLOCK-DEVICE; M, F - FORMATTING; p - PARTITION
Columns: SLOT, MODEL, SERIAL, INTERFACE, SIZE, FREE, FS, RAID-MASTER, NFS-STATE
SLOT MODEL SERIAL INTERFACE SIZE FREE FS RAID-MASTER NFS-STATE
0 magnetonas nfs://172.29.45.251/volume1/Mikrotik network none Protocol not supported
So this ROSE-package support (only) NFSv4 right ? (I tried enabling/disabling NFSv4.1 on the NAS, no difference)
Hmm, I can’t really force that on the NAS. I can enable/disable NFSv4.1 , but other than that its “enable or disable” NFS as a whole.
Is there some command-flag on the ROSE package to force NFSv3 ? (doesn’t like like it…)
