Hi.
Iam recently updated my router, switch and a few of wAP ac to ROS7 (7.14.2). CAPsMAN was previously configured on ROS6, so, after migrating to ROS7 it is still functional, but on old drivers. I manually remove “wireless” package from router and AP’s and install “wifi-qcom-ac-7.14.2-arm.npk” to AP’s. After this, new WiFi driver + new CAPsMAN was easily setted up, and all works fine as before.
I was configured two networks with next channels: 2.4 GHz for max N band and 5.0 GHz for max AC band. In ROS6 it was 2.4GHz b/g/n and 5GHz smth respectively.
But, a few devices now cant connect to the new wireless network: all of its is “Mitsubishi Electric Wi-Fi Interface (MAC-567IF-E1)”. In manual to this device is clearly stands that supported bands is “IEEE 802.11b/g/n (20)” and radiochannels is “1–13 (2412–2472 МГц)”.
I think main issue is that 802.11b is unsupported OR unused, because since once upon a time I tried to configure a 2.4 GHz wireless network on ROS6 only for N band and the same devices also could not connect to this network.
Searching the forum, Iam find some discussions (one, two) about 802.11b support, from the text of which it is clear that ROS7 WiFi definitely supported 802.11b, moreover, it cannot be disabled. But, looking at WinBox the configuration menu for channels, provisions, radio actually openened channels, I don’t see any B band mention anywhere, only N and G.
Can anyone please explain how to configure 802.11b in ROS7? Or, maybe, how to avoid connection issues with my fault devices.
Thank you.
Screenshot of few menus where 802.11b must be present (I think it might be):
