802.11n Problem. MCS-15 not working.
Seems like MCS-15 is not working on RB SXT v5.0 RC8. (2 spatial streams, 64 QAM, 5/6 coding rate)
Max tx/rx rate i get is 130 mbps (20 Mhz) or 270 Mbps (40 Mhz). This is only MCS-14 modulation scheme at 400 ns guard interval.
I had the two polarisation enabled. And a large signal / noise ratio (62 dB)
Other problem :
I tried to change MCS set through console, (it is not possible to do it via Winbox).
After reducing basic and supported rate to MCS0 - MCS2, i still was able to connect at MCS-14.
Atheros problem or did i miss something ?
what wireless protocol you are using?
270mbps is also mcs-15 with 800ns guard interval.
I’m using NV2, with HT Guard interval “any”.
HT Tx and RX chains 0 and 1 enabled.
We can see in the registered station window that HT40-7 (MCS15 ?) is not receiving packets.
NV2 only supports 800ms guard at this time. You will not get 300 / 150 only 270 / 135.
Ok, this is not clear inside Winbox as there are two settings for Guard Interval even if NV2 is active :
  • any
  • long
Those settings are ignored for Nv2. Nv2 doesn’t support short guard interval.
Ok.
They should be grayed out if not used, so that users are not confused.
Can be extended to other details inside Winbox.
