A question regarding DHCP-server and NTP option
Hello.
First of all, I am new to RouterOS.
:smiley:
Thanks to everyone who will take time to read my post.
I have a question regarding DHCP-server and NTP.
Before posting I searched on the forums and on the web, but I found only this similar post:
http://forum.mikrotik.com/t/disable-announcing-ntp-server-in-dhcp/92544/1
unfortunately without answers.
I recently replaced my home router with a CRS109-8G-1S-2HnD running version 6.33.2 (stable).
It serves as a DHCP server for my clients.
I also configured it as a client to an NTP server I run in my network:
The configuration is:
CRS109 → 192.168.25.1 (MikroTik router)
NTPserver → 192.168.25.62 (my NTP server)
[admin@MikroTik] > /system ntp client print
             enabled: yes
         primary-ntp: 192.168.25.62
    server-dns-names:
                mode: unicast
       poll-interval: 15m
       active-server: 192.168.25.62
    last-update-from: 192.168.25.62
  last-update-before: 6m6s790ms
     last-adjustment: 5ms925us
[admin@MikroTik] >
So far, so well.
But I have noticed that it provides to the clients the address of its NTP server, even though (I believe) it is not configured to do this (no NTP server, nor any option configured in the DHCP-server):
[admin@MikroTik] > /ip dhcp-server network print detail
 0 ;;; default configuration
   address=192.168.25.0/24 gateway=192.168.25.1 netmask=24 dns-server=192.168.25.1 wins-server="" ntp-server="" caps-manager="" dhcp-option=""
[admin@MikroTik] >
[admin@MikroTik] > /ip dhcp-server option print
 # NAME                      CODE VALUE         RAW-VALUE
[admin@MikroTik] >
I have verified that on all of my clients (all are linux boxes) that get the address from the DHCP, they receive the NTP server as well.
I have tested a virtual machine with CHR (updated to 6.33.2 stable), and captured some packets.
It has the mac address 08:00:27:a5:a4:50, and receives the address 192.168.25.253
See below the discover, request and ack packets from the DHCP conversation.
My doubt is: since the DHCP server is not configured to send the NTP information to the clients, is it correct that the NTP server is sent to the client?
Or is this a wrong configuration on my side?
Thanks,
Andrea
## DHCP CONVERSATION ##
## DISCOVER ##
Frame 17181: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits)
Ethernet II, Src: xx:xx:xx:xx:xx:xx (xx:xx:xx:xx:xx:xx), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 0.0.0.0 (0.0.0.0), Dst: 255.255.255.255 (255.255.255.255)
User Datagram Protocol, Src Port: 68 (68), Dst Port: 67 (67)
Bootstrap Protocol (Discover)
    Message type: Boot Request (1)
    Hardware type: Ethernet (0x01)
    Hardware address length: 6
    Hops: 0
    Transaction ID: 0x1ac1b8ab
    Seconds elapsed: 0
    Bootp flags: 0x8000, Broadcast flag (Broadcast)
        1... .... .... .... = Broadcast flag: Broadcast
        .000 0000 0000 0000 = Reserved flags: 0x0000
    Client IP address: 0.0.0.0 (0.0.0.0)
    Your (client) IP address: 0.0.0.0 (0.0.0.0)
    Next server IP address: 0.0.0.0 (0.0.0.0)
    Relay agent IP address: 0.0.0.0 (0.0.0.0)
    Client MAC address: 08:00:27:a5:a4:50 (08:00:27:a5:a4:50)
    Client hardware address padding: 00000000000000000000
    Server host name not given
    Boot file name not given
    Magic cookie: DHCP
    Option: (53) DHCP Message Type (Discover)
        Length: 1
        DHCP: Discover (1)
    Option: (55) Parameter Request List
        Length: 7
        Parameter Request List Item: (1) Subnet Mask
        Parameter Request List Item: (121) Classless Static Route
        Parameter Request List Item: (3) Router
        Parameter Request List Item: (33) Static Route
        Parameter Request List Item: (6) Domain Name Server
        Parameter Request List Item: (42) Network Time Protocol Servers
        Parameter Request List Item: (138) CAPWAP Access Controllers
    Option: (255) End
        Option End: 255
    Padding: 000000000000000000000000000000000000000000000000...
## REQUEST ##
Frame 17186: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits)
Bootstrap Protocol (Request)
    Hops: 0
    Seconds elapsed: 0
    Magic cookie: DHCP
    Option: (53) DHCP Message Type (Request)
        Length: 1
        DHCP: Request (3)
    Option: (54) DHCP Server Identifier
        Length: 4
        DHCP Server Identifier: 192.168.25.1 (192.168.25.1)
    Option: (50) Requested IP Address
        Length: 4
        Requested IP Address: 192.168.25.253 (192.168.25.253)
        Length: 7
    Option: (255) End
        Option End: 255
## ACK ##
Frame 17188: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits)
Ethernet II, Src: Routerbo_xx:xx:xx (e4:8d:8c:xx:xx:xx), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 192.168.25.1 (192.168.25.1), Dst: 255.255.255.255 (255.255.255.255)
User Datagram Protocol, Src Port: 67 (67), Dst Port: 68 (68)
Bootstrap Protocol (ACK)
    Message type: Boot Reply (2)
    Hops: 0
    Seconds elapsed: 0
    Your (client) IP address: 192.168.25.253 (192.168.25.253)
    Next server IP address: 192.168.25.1 (192.168.25.1)
    Magic cookie: DHCP
    Option: (53) DHCP Message Type (ACK)
        Length: 1
        DHCP: ACK (5)
        Length: 4
    Option: (51) IP Address Lease Time
        Length: 4
        IP Address Lease Time: (43200s) 12 hours
    Option: (1) Subnet Mask
        Length: 4
        Subnet Mask: 255.255.255.0 (255.255.255.0)
    Option: (3) Router
        Length: 4
        Router: 192.168.25.1 (192.168.25.1)
    Option: (6) Domain Name Server
        Length: 4
        Domain Name Server: 192.168.25.1 (192.168.25.1)
    Option: (42) Network Time Protocol Servers
        Length: 4
        Network Time Protocol Server: 192.168.25.62 (192.168.25.62)
    Option: (255) End
        Option End: 255
bump?
No one noticed this behaviour?
Thanks!
This is ROS default behaviour : DHCP - RouterOS - MikroTik Documentation
| ntp-none (yes | no; Default: no) | If set, then DHCP Server will not pass NTP servers configured on the router to the DHCP clients. |
Because the default to this ntp-none setting is no, you have to read the contrary of the description to understand the default behaviour, which is : DHCP Server will pass NTP servers configured on the router to the DHCP clients.
The same goes for DNS by the way
| dns-none (yes | no; Default: no) | If set, then DHCP Server will not pass DNS servers configured on the router to the DHCP clients. |
