I’ve blocked youtube.com at my office using regex (^.+(youtu|youtube).*$) + firewall access rule:
chain:input
action:drop
Layer7Protocol:Youtube
Youtube is blocked at the moment, but merlion.com could not be opened now. When I disable firewall access rule which block youtube.com, merlion.com opens fine.
What is the connection? I don’t understand!!! Because of this site I can’t block youtube!
Of course. The rule you made, blocks by content, not by name. You will block any site, that has Youtube written anywhere on the page or other places.
L7 rules are not meant for blocking pages and will not work like you intended.
For page blocking by name, use proxy (which will not work for https traffic like youtube), or DNS names (maybe catch DNS traffic with your router, and redirect to where you will filter it)
Sites facebook.com, youtu.be, youtube.com could not be filtered using IP > WebProxy functionality. There no hits for them.
So, I’ve gone deeper and tried to apply Layer7 inspection. It worked, but the result with URLs like merlion.com is inacceptible.
Could you please give me a link how to configure “blocking by DNS name”?
P.S. Actually, my device works as proxy. I have main provider in the office and use 751+4G as additional ISP, redirecting HTTP, HTTPS traffic from clients to Mikrotik.
https is encrypted, you can’t filter https traffic using proxy.
You can use external service like OpenDNS to block using DNS, router will only capture traffic and redirect it to opendns.
Or you can use IP → DNS → Static to configure some other IP address for the blocked site, for example 127.0.0.1
