Digging up an old IKEv2 RSA problem (VPN Android 13+ no-longer-L2TP chapter), I spent one night figuring why something working (that long time a ago)… stopped working.
Well, I blamed everything except ROS version, until I dug up an old 7.6 router that worked OOB with my old config and certificates.
I then pinpointed the braking point to be 7.9 (7.8 still working with no minor version).
I think it was discussed back then, 2 years later not working anymore.
Yes, maybe a lot of folks switched to StrongSwan, Wireguard or OpenVPV after that, but why not using native tools and software from Android and Mikrotik, not relying on third party?
If someone is using IKEv2 RSA with Android 13+ using native VPN please present the IPSEC setup.
I am almost sure that my setup with 7.19.2 (current) will work fine with Win10+ built-in VPN. Lazy as I am still babbling with where to put exactly the certificates for user/computer and not importing/copying them all over like I currently do.
Only thing that is not included and to bear in mind is that the server certificate should include as a common and alternative name the IP address/DNS name of the server.
Proposal and profile encryption parameters are adjusted for a Samsung phone running latest Android version
Thank you for the config. Pretty much is the same as mine, i adjusted mine to yours, same results, unsuccessful connection.
The only thing missing from my setup is the IP Addresses setting, where you use the “loopback” interface but I do not have that in my list. I tried to use that from terminal but same results: input does not match any value of interfaces. Should I try to create “loopback”?
About that loopback interface, can you tell me your ROS version, as I remember having loopback in 6.x, but maybe I am mistaken.
As i said in my message, my setup worked until ROS version 7.8, then failed gracefully.
ROS version is 7.12.1 and the loopback interface was made before the “unearthing” of the built-in one. It’s just a blank bridge, to which I can assign an address. If you can export the IPsec log during a connection attempt and post it here, I could try and see where the problem is:
