Access equipment on hotspot interface
We have turned a RB750 into a hotspot controller for around 75 users. ETH1 has the address 10.0.0.2 and ETH2 has 192.168.1.1. NAT is in operation between the 2 address ranges and a hotspot service also runs on ETH2. 2 Access points sit on the ETH2 side with addresses 192.168.1.10 and 192.168.1.11. Does anyone know if there is an easy way for us to access the APs from the ETH1 side (10.0.0.0 range)? We VPN into the system to modify settings as its on a remote site but this drops us onto the ETH1 side. It will also be useful for DUDE to check on this equipment but the dude server is also sat on the ETH1 side and cannot see equipment attached to ETH2. On a different vendors equipment (now replaced by the MT unit) it was possible to create a 1on1 NAT connection between the 2 interfaces. Is this possible with MT?
Thanks all very much. Jon
Yes, of course it is possible in MikroTik too,
http://wiki.mikrotik.com/wiki/How_to_link_Public_addresses_to_Local_ones
Thanks a million for that. Works a treat
