I have mikrotik os 2.9.24,
i wan access to my router out sid my country,i wan put in address bar 192.168.1.99 for with port=12088 for example ,access me to enter my router ,can any one tell me how i configuration my router,
192.168.1.99 is private address. you should use public one instead. and you may change www port under /ip service menu
ok very thnx but can you tell me how do configuration
well, if you have public IP, you should know it =) llok in /ip address print
how u want to access???
By winbox or ssh???
if u want to access by winbox then
//ip firewall filter rules add input= (ur remote side ip address) action=accept
if u want to access by ssh/telnet/ftp then
// ip service available from = (ur remote adress)
try it… i think it will work now
thnxs,
raktim
