Access servers on private net via SSTP
I have been on a journey the last few days setting up an RB750GL with 5.7 as a NAT’s home router with an SSTP VPN server. The router config is little changed from the default except for SSTP.
With the help of the forum SSTP works and I can, via the VPN, access private router ports, winbox for example. I am now stuck trying figure out how to allow VPN users to access servers on the private network.
Tips or pointers would be appreciated.
Sincerely.
Larry
Larry, do you have any routes on VPN clients?
routes should point to remove servers with SSTP tunnel remote address as gateway, remote servers should be aware of SSTP clients IP addresses as well.
Both examples explains exactly what you need
http://wiki.mikrotik.com/wiki/SSTP#Application_Examples
Thank you.
I totally missed the proxy-arp at the bottom of the client section
Makes sense and all is working very well.
Larry
