Actual Driver Support 40G Cards on ROS 6.47.x/6.48x
Hello, i found a few old topics about the Intel XL 710 Driver (10G/40G). Maybe someone could give me an actual status:
  • is ROS 6.47.x/6.48.x based on kernel version 5.x. If not does it based on kernel version 3.3.5 as written in the wiki (from 2019) ?
Background of my questions is:
  • Does ROS 6.47.x/6.48.x support Intel XL 710 Network driver?
Kind regards,
glueck
ROS v6 (up to latest releases) is based on same old linux kernel. ROS v7 will be based on modern linux kernels.
Whatever that means re support for XL710 NICs.
If you use a Mikrotik CHR on a virtual machine the virtual host will have the driver.
thank you very much for the information but i don’t use chr. I am just interessted in running ROS direct X86 Hardware.
regards,
glueck
The x86 release of RouterOS 6 is not really made for high performance workloads, more like single-boards computers and embedded stuff.
Use CHR release on top of KVM or whatever.
I can report:
System used:
With: Intel Xeon Silver 4215R:
https://www.landitec.com/products/x86-n … 20-detail/
10G Cards:
Revsion-A has 10G onboard
40G Cards (i am sure that Intel XL 710 is not supported by Ros 6.47.beta58):
https://www.lannerinc.com/products/netw … cs2-iqm201
10G: Ethernet Connection X722 for 10GbE SFP+ (rev: 4)
ROS 6.48.beta58: unknown device (=Device not found)
ROS v7.1.beta2: Ethernet Connection X722 for 10GbE SFP+ (rev: 4)
40G: Ethernet Controller XL710 for 40GbE QSFP+ (rev: 2)
ROS v7.1.beta2: Ethernet Controller XL710 for 40GbE QSFP+ (rev: 2)
[admin@MikroTik] > system/resource/print
                   uptime: 2m33s
                  version: 7.1beta2 (development)
               build-time: Aug/21/2020 12:29:19
              free-memory: 30.6GiB
             total-memory: 31.0GiB
                      cpu: Intel(R)
                cpu-count: 16
            cpu-frequency: 3200MHz
                 cpu-load: 0%
           free-hdd-space: 221.7GiB
          total-hdd-space: 221.7GiB
  write-sect-since-reboot: 433
         write-sect-total: 433
        architecture-name: x86_64
               board-name: x86
                 platform: MikroTik
[admin@MikroTik] > system/resource/pci/print
Columns: DEVICE, VENDOR, NAME, IRQ
    #  DEVICE   VENDOR                   NAME                                                             IR
    0  00:00.0  Intel Corporation        Sky Lake-E DMI3 Registers (rev: 7)                                0
    1  00:04.0  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              11
    2  00:04.1  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              10
    3  00:04.2  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              11
    4  00:04.3  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              11
    5  00:04.4  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              11
    6  00:04.5  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              10
    7  00:04.6  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              11
    8  00:04.7  Intel Corporation        Sky Lake-E CBDMA Registers (rev: 7)                              11
    9  00:05.0  Intel Corporation        Sky Lake-E MM/Vt-d Configuration Registers (rev: 7)               0
   10  00:05.2  Intel Corporation        Sky Lake-E RAS (rev: 7)                                           0
   11  00:05.4  Intel Corporation        Sky Lake-E IOAPIC (rev: 7)                                        0
   12  00:08.0  Intel Corporation        Sky Lake-E Ubox Registers (rev: 7)                                0
   13  00:08.1  Intel Corporation        Sky Lake-E Ubox Registers (rev: 7)                                0
   14  00:08.2  Intel Corporation        Sky Lake-E Ubox Registers (rev: 7)                                0
   15  00:11.0  Intel Corporation        C620 Series Chipset Family MROM 0 (rev: 4)                        0
   16  00:14.0  Intel Corporation        C620 Series Chipset Family USB 3.0 xHCI Controller (rev: 4)      11
   17  00:16.0  Intel Corporation        C620 Series Chipset Family MEI Controller #1 (rev: 4)            11
   18  00:16.4  Intel Corporation        C620 Series Chipset Family MEI Controller #3 (rev: 4)            11
   19  00:17.0  Intel Corporation        C620 Series Chipset Family SATA Controller [AHCI mode] (rev: 4)  11
   20  00:1c.0  Intel Corporation        C620 Series Chipset Family PCI Express Root Port #1 (rev: 244)   11
   21  00:1c.2  Intel Corporation        C620 Series Chipset Family PCI Express Root Port #3 (rev: 244)   11
   22  00:1f.0  Intel Corporation        C626 Series Chipset LPC/eSPI Controller (rev: 4)                  0
   23  00:1f.2  Intel Corporation        C620 Series Chipset Family Power Management Controller (rev: 4)   0
   24  00:1f.4  Intel Corporation        C620 Series Chipset Family SMBus (rev: 4)                         0
   25  00:1f.5  Intel Corporation        C620 Series Chipset Family SPI Controller (rev: 4)                0
   26  01:00.0  Intel Corporation        I210 Gigabit Network Connection (rev: 3)                         11
   27  02:00.0  ASPEED Technology, Inc.  AST1150 PCI-to-PCI Bridge (rev: 3)                                0
   28  03:00.0  ASPEED Technology, Inc.  ASPEED Graphics Family (rev: 48)                                 11
   29  16:01.0  Intel Corporation        Sky Lake-E PCI Express Root Port B (rev: 7)                      11
   30  16:02.0  Intel Corporation        Sky Lake-E PCI Express Root Port C (rev: 7)                      11
   31  16:05.0  Intel Corporation        Sky Lake-E VT-d (rev: 7)                                          0
   32  16:05.2  Intel Corporation        Sky Lake-E RAS Configuration Registers (rev: 7)                   0
   33  16:05.4  Intel Corporation        Sky Lake-E IOxAPIC Configuration Registers (rev: 7)               0
   34  16:08.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   35  16:08.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   36  16:08.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   37  16:08.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   38  16:08.4  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   39  16:08.5  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   40  16:08.6  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   41  16:08.7  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   42  16:09.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   43  16:09.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   44  16:09.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   45  16:09.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   46  16:09.4  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   47  16:09.5  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   48  16:09.6  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   49  16:09.7  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   50  16:0a.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   51  16:0a.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   52  16:0a.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   53  16:0a.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   54  16:0a.4  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   55  16:0a.5  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   56  16:0a.6  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   57  16:0a.7  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   58  16:0b.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   59  16:0b.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   60  16:0b.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   61  16:0b.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   62  16:0e.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   63  16:0e.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   64  16:0e.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   65  16:0e.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   66  16:0e.4  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   67  16:0e.5  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   68  16:0e.6  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   69  16:0e.7  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   70  16:0f.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   71  16:0f.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   72  16:0f.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   73  16:0f.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   74  16:0f.4  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   75  16:0f.5  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   76  16:0f.6  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   77  16:0f.7  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   78  16:10.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   79  16:10.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   80  16:10.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   81  16:10.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   82  16:10.4  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   83  16:10.5  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   84  16:10.6  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   85  16:10.7  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   86  16:11.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   87  16:11.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   88  16:11.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   89  16:11.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   90  16:1d.0  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   91  16:1d.1  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   92  16:1d.2  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   93  16:1d.3  Intel Corporation        Sky Lake-E CHA Registers (rev: 7)                                 0
   94  16:1e.0  Intel Corporation        Sky Lake-E PCU Registers (rev: 7)                                 0
   95  16:1e.1  Intel Corporation        Sky Lake-E PCU Registers (rev: 7)                                 0
   96  16:1e.2  Intel Corporation        Sky Lake-E PCU Registers (rev: 7)                                 0
   97  16:1e.3  Intel Corporation        Sky Lake-E PCU Registers (rev: 7)                                 0
   98  16:1e.4  Intel Corporation        Sky Lake-E PCU Registers (rev: 7)                                 0
   99  16:1e.5  Intel Corporation        Sky Lake-E PCU Registers (rev: 7)                                 0
  100  16:1e.6  Intel Corporation        Sky Lake-E PCU Registers (rev: 7)                                 0
  101  17:00.0  Intel Corporation        I350 Gigabit Network Connection (rev: 1)                         11
  102  17:00.1  Intel Corporation        I350 Gigabit Network Connection (rev: 1)                         10
  103  17:00.2  Intel Corporation        I350 Gigabit Network Connection (rev: 1)                         11
  104  17:00.3  Intel Corporation        I350 Gigabit Network Connection (rev: 1)                         11
  105  18:00.0  Intel Corporation        Ethernet Controller XL710 for 40GbE QSFP+ (rev: 2)               11
  106  18:00.1  Intel Corporation        Ethernet Controller XL710 for 40GbE QSFP+ (rev: 2)               11
  107  64:02.0  Intel Corporation        Sky Lake-E PCI Express Root Port C (rev: 7)                      11
  108  64:05.0  Intel Corporation        Sky Lake-E VT-d (rev: 7)                                          0
  109  64:05.2  Intel Corporation        Sky Lake-E RAS Configuration Registers (rev: 7)                   0
  110  64:05.4  Intel Corporation        Sky Lake-E IOxAPIC Configuration Registers (rev: 7)               0
  111  64:08.0  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  112  64:09.0  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  113  64:0a.0  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  114  64:0a.1  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  115  64:0a.2  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  116  64:0a.3  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  117  64:0a.4  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  118  64:0a.5  Intel Corporation        Sky Lake-E LM Channel 1 (rev: 7)                                  0
  119  64:0a.6  Intel Corporation        Sky Lake-E LMS Channel 1 (rev: 7)                                 0
  120  64:0a.7  Intel Corporation        Sky Lake-E LMDP Channel 1 (rev: 7)                                0
  121  64:0b.0  Intel Corporation        Sky Lake-E DECS Channel 2 (rev: 7)                                0
  122  64:0b.1  Intel Corporation        Sky Lake-E LM Channel 2 (rev: 7)                                  0
  123  64:0b.2  Intel Corporation        Sky Lake-E LMS Channel 2 (rev: 7)                                 0
  124  64:0b.3  Intel Corporation        Sky Lake-E LMDP Channel 2 (rev: 7)                                0
  125  64:0c.0  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  126  64:0c.1  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  127  64:0c.2  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  128  64:0c.3  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  129  64:0c.4  Intel Corporation        Sky Lake-E Integrated Memory Controller (rev: 7)                  0
  130  64:0c.5  Intel Corporation        Sky Lake-E LM Channel 1 (rev: 7)                                  0
  131  64:0c.6  Intel Corporation        Sky Lake-E LMS Channel 1 (rev: 7)                                 0
  132  64:0c.7  Intel Corporation        Sky Lake-E LMDP Channel 1 (rev: 7)                                0
  133  64:0d.0  Intel Corporation        Sky Lake-E DECS Channel 2 (rev: 7)                                0
  134  64:0d.1  Intel Corporation        Sky Lake-E LM Channel 2 (rev: 7)                                  0
  135  64:0d.2  Intel Corporation        Sky Lake-E LMS Channel 2 (rev: 7)                                 0
  136  64:0d.3  Intel Corporation        Sky Lake-E LMDP Channel 2 (rev: 7)                                0
  137  65:00.0  Intel Corporation        unknown device (rev: 4)                                          11
  138  66:00.0  Intel Corporation        unknown device (rev: 4)                                          11
  139  66:02.0  Intel Corporation        unknown device (rev: 4)                                          11
  140  66:03.0  Intel Corporation        unknown device (rev: 4)                                          11
  141  67:00.0  Intel Corporation        C62x Chipset QuickAssist Technology (rev: 4)                     11
  142  68:00.0  Intel Corporation        C62x Chipset QuickAssist Technology (rev: 4)                     11
  143  69:00.0  Intel Corporation        Ethernet Connection X722 for 10GbE SFP+ (rev: 4)                 11
  144  69:00.1  Intel Corporation        Ethernet Connection X722 for 10GbE SFP+ (rev: 4)                 11
  145  69:00.2  Intel Corporation        Ethernet Connection X722 for 10GbE SFP+ (rev: 4)                 11
  146  69:00.3  Intel Corporation        Ethernet Connection X722 for 10GbE SFP+ (rev: 4)                 11
  147  b2:05.0  Intel Corporation        Sky Lake-E VT-d (rev: 7)                                          0
  148  b2:05.2  Intel Corporation        Sky Lake-E RAS Configuration Registers (rev: 7)                   0
  149  b2:05.4  Intel Corporation        Sky Lake-E IOxAPIC Configuration Registers (rev: 7)               0
  150  b2:0e.0  Intel Corporation        Sky Lake-E KTI 0 (rev: 7)                                         0
  151  b2:0e.1  Intel Corporation        Sky Lake-E UPI Registers (rev: 7)                                 0
  152  b2:0f.0  Intel Corporation        Sky Lake-E KTI 0 (rev: 7)                                         0
  153  b2:0f.1  Intel Corporation        Sky Lake-E UPI Registers (rev: 7)                                 0
  154  b2:10.0  Intel Corporation        Sky Lake-E KTI 0 (rev: 7)                                         0
  155  b2:10.1  Intel Corporation        Sky Lake-E UPI Registers (rev: 7)                                 0
  156  b2:12.0  Intel Corporation        Sky Lake-E M3KTI Registers (rev: 7)                               0
  157  b2:12.1  Intel Corporation        Sky Lake-E M3KTI Registers (rev: 7)                               0
  158  b2:12.2  Intel Corporation        Sky Lake-E M3KTI Registers (rev: 7)                               0
  159  b2:12.4  Intel Corporation        Sky Lake-E M3KTI Registers (rev: 7)                               0
  160  b2:12.5  Intel Corporation        Sky Lake-E M3KTI Registers (rev: 7)                               0
  161  b2:15.0  Intel Corporation        Sky Lake-E M2PCI Registers (rev: 7)                               0
  162  b2:15.1  Intel Corporation        Sky Lake-E DDRIO Registers (rev: 7)                               0
  163  b2:16.0  Intel Corporation        Sky Lake-E M2PCI Registers (rev: 7)                               0
  164  b2:16.1  Intel Corporation        Sky Lake-E DDRIO Registers (rev: 7)                               0
  165  b2:16.4  Intel Corporation        Sky Lake-E M2PCI Registers (rev: 7)                               0
  166  b2:16.5  Intel Corporation        Sky Lake-E DDRIO Registers (rev: 7)                               0
  167  b2:17.0  Intel Corporation        Sky Lake-E M2PCI Registers (rev: 7)                               0
  168  b2:17.1  Intel Corporation        Sky Lake-E DDRIO Registers (rev: 7)                               0
Short local test:
[admin@MikroTik] > tool/bandwidth-test address=1.1.1.1
                    ;;; results can be limited by cpu, note that traffic generation/termination performance might not be representative of forwarding performance
                status: running
              duration: 16s
            rx-current: 615.2Gbps
  rx-10-second-average: 404.8Gbps
      rx-total-average: 277.4Gbps
          lost-packets: 0
           random-data: no
             direction: receive
               rx-size: 65535
      connection-count: 20
        local-cpu-load: 92%
       remote-cpu-load: 92%
Thx for the post. Was looking for more info on rosv7 driver support. Planning on upgrading my Lanner x86 machines to xeon scalable family. I see your using xeon silver. Your btest seems even abit more than I was anticipating. Thx again. Im more confident now..
Hi, we just installed ROS7.7 on x86 with the AOC-S40G-I2Q card and it works without any problems.
We just ran into the problem that the queues can’t be split into individual cores. All queues are hanging on one core.
Please, can you say about your x86 router status? How many traffic real time? BGP? OSPF? CGNat? Pppoe server?
Just change BIOS Configuration
We run 5x NCA-5520A (with 1 x Intel Xeon Silver 4215R and 3x NCS2-IXM405A) on ROS 6.84.6 as BRAS with max 8000 Session per System (average Users per System: ~ 4000). In case of maintance or failure i see 6000 Session without any Problem. On last Champins League Playday with ~ 13,6 Gb/s max per System.
Hiya.. can u please confirm to us what kind of server hardware beeing used? Dell? supermicro? xeon cpu family? memory? any chance of getting a 100G card running? on routerOS? i am planning to build up a BGP hardware server machine.. and retire our ccr1072 BGP.. i am looking into a good server hardware stable for the next couple of years.. and some BRAS powerfull for up to 5k to 10k pppoe-connections server side also.
You use NCA-5520A with 10g nic? You 8k pppoe sessions per device?
I want to know, does you use 40g nic?
We use the supermicro server. Can you please guide me what to change in the bios to make the card have more threads? Thank you
We use supermicro server with intel desktop processor W series. There is only BGP about 50 peers and a total of about 5mil rout. ipv4 and ipv6 and up to 30 firewall rules.
Hi
has anyone tried the MCX416A-CCAT ConnectX-4 on RouterOS V7? i have found some pretty good deal prices on this cards i was wondering if this would be supported on RouterOS x86_64 v7
