Dear All. have a RB2011 router with CapsMan for shared AP CAPs management.
In RouterBoard page:
Model RB2011iL
Revision r3
Firmware Type ar9344
Factory Firmware 6.47.4
Current Firmware 7.11.2
Upgrade Firmware 7.12.1
In Check for Updates page:
Installed Version 7.12.1
Latest Version 7.16.2
I have 2 CAPS for it, which work normally as CAPs.
Model RBcAPL-2nD
Firmware Type qca9531L
Factory Firmware 6.44
Current Firmware 6.45.9
Upgrade Firmware 7.16.2
Installed Version 7.16.2
I want to add a third AP, type CAP AX
Model cAPGi-5HaxD2HaxD
Firmware Type ipq6000
Factory Firmware 7.8
Current Firmware 7.8
I reset this CAP AX for 10 seconds for CapsMan mode and the wifi-qcom package was installed.
The problem is that I can't set this CAP to work with the router. Either there is a problem, or I don't know the procedure.
It would certainly be advisable to unify all firmware versions, but some are said to be old HW and some are new HW and I don't know where the common firmware versions intersect.
According to the indications I found on the forum, it is supposedly necessary to also install the wifi-qcom package on the main RB2011 router to change the CapsMan version from version 1 to version 2, but this is just speculation, is it true? Will the CapsMan version change after installing the package and will the Wifi settings in CapsMan be lost?
