I’m trying to add a dynamic IP address to a list, but I ran into a few issues. I can add a variable like the following to get the address.
:set wanip [/ip address get [/ip address find interface=ether1] address]
The problem when I’m trying to add the address with the following command is that the network address will be added instead of the IP address. I need to remove the Bit mask from the IP address, and I have no clue for the moment how I can do that.
Obviously, this command will simply add a new address when it changes, so I need to remove the old address before adding a new one. The simplest way would be to use the remove parameter, but I’ve not figured out the proper command.
I have in mind to use it with a nat rule, so people can browse the web server behind nat using the Public IP address. I want to get rid of one DNS server to simplify everything.
Here is the rules that made it possible to browse a web server behind nat using the Public IP address (frequently asked by many people in this forum). This feature has many names, for example: Nat Loopback, Nat Reflection, or Nat Bouncing.
I only used the first line until I realized that it will be problem if there is a delay in the dhcp lease when the router is rebooted, or the router does not get any IP address at all. But you’re right, I only need the line you pointed out.
I just realized that I need another check. When the router reboots, the init script is trying to add the IP address to the address list. If the address has changed, then I’ll have two addresses in the list, and that is something I don’t want. I also found out that the same address can be added multiple times in the address list. This should not be possible, but sometimes it’s possible to add an existing IP address multiple times (bug in the RouterOS?).
Anyhow, here is the line I want to do something about. I want to change the address if there is already an IP address in the list, and if the list does not exist, run the following line.
The easiest way would be to manually add the address in the beginning, and then use the following line to change the address. But why do it simple? I want to make it foolproof.
:foreach a in=[/ip firewall address-list find list=wan_ip] do={/ip firewall address-list set $a address=$wanip}}
I created this script to get the list of interfaces from the /interface list members list then get their IP addresses and add it to the firewall addresses list.
Get list of interfaces
Get their addresses
Add addresses to firewall list
Remove old addresses from firewall list
:local iflist "WAN"
:local fwlist "public"
:local interfaces [/interface list member find where list=$iflist]
:local newaddrs
:foreach a in $interfaces do={
:local ifname [/interface list member get number=$a value-name=interface]
#:put $ifname
:local ifaddrs [/ip address find where interface=$ifname]
:foreach b in $ifaddrs do={
:local ifaddr [/ip address get number=$b value-name=address]
# Remove network mask
:set ifaddr [:pick $ifaddr 0 [:find $ifaddr "/"]]
#:put $ifaddr
:set $newaddrs ($newaddrs, $ifaddr)
# Add new addresses
:foreach a in $newaddrs do={
:if ([/ip firewall address-list find where address=$a] = "") do={
/ip firewall address-list add list=$fwlist address=$a
# Remove old addresses
:foreach a in [/ip firewall address-list find where list=$fwlist] do={
:local addr [/ip firewall address-list get number=$a value-name=address]
#:put $addr
:if ([:len [:find $newaddrs $addr]] = 0) do={
/ip firewall address-list remove $a
You resurrect a 2007 topic with this script,
but what is one useful way to use this script?,
considering that now in the firewall it is already possible
to specify the WAN list of the interfaces, without using the IPs?
the correct syntax want = betwen in and the variable
in $ => in=$
why ckeck if the address is used on any other list?
why you do not add the address if is on another list?
and why remove old addresses AFTER add new addres,
in so complicate way, first mix all old and new and then delete what is not just added?
Next time di point 4, then point 3…
And why do not direct create entry on address list, instead of create the array of addresses first, then add the addresses on the list?
Simply add the addresses after removing all first, ignoring if the addresses are used on other lists…
after some other corrections, for teaching purposes, simply do:
:local iflist "WAN"
/ip firewall address-list remove [find where list=$fwlist]
:foreach memberid in=[find where list=$iflist] do={
:local ifname [get $memberid interface]
:foreach addressid in=[/ip address find where interface=$ifname] do={
:local ifaddr [/ip address get $addressid address]
:set ifaddr [:pick $ifaddr -1 [:find $ifaddr "/"]]
/ip firewall address-list add list=$fwlist address=$ifaddr
