Added LAN interface to bridge?
Yes I am. If you wanted to make contact you could message their mikrotik channel and I'll keep an eye out for you. In the meantime, if you'd like to explore more about the premade stuff from EXEN you can go to his site - https://exen.sh/
He sells both the stick and the cooler as well as DIY kits if you're so inclined. He has two main coolers, one formed for the unifi cloud gateway, another that just clips over the stick for everything else. It's a really slim form factor so even with the ports next to it in use, the stick and its cooler both fit without any clearance issues that might make them press against other cables. That was one of my worries with the RB5009 since the sfp port is really close to the power port, but it worked out great.
I'll definitely check that out. Along with the virtual router, they seem like great tools. Might just end up purchasing a hex to tamper with things without any real risk too. fifty bucks to not have to worry about locking myself out or security issues is starting to look worth it lol.
@Buckeye
Nothing particular, a Dell laptop running Windows 10.
But you need more than 8 GB RAM to run It comfortably, because you will be running a VM, either Virtualbox or VMware.
Which one Is a mistery, I have another install on a desktop running Windows 7 that runs Virtualbox (and not VMware), while on the Dell It Is VMware because Virtualbox won't run.
Overall It Is a mess with the settings of the virtual network adapters and I have rarely seen softwares with more confusing settings.
But with a bit of patience the difficulties can be overcome, though from time to time the GNS3 will refuse to start, for no apparent reasons but providing completely misleading error messages.
Usually fiddling with some settings, starting with a new project instead of Opening an existing One, waiting For several seconds for something to load, shouting at the stupid GNS3 a couple of times solves the issue and the stupid thingy starts again and works fine for the next n boots.
All in all a terribile mish-mash of a software, badly designed and terribly documented, but when/if It runs extremely handy and useful.
I have an old OptiPlex 7020 Small Form Factor (End of Life) (2015) with win10 pro and 16GB RAM. I will have to try loading it. Downside, it has a 500GB HDD not an SSD. So I don't know if that will make it painfully slow or not.
Don't worry, the installation the desktop is on HDD too and it is not particularly slow (in the sense of responsiveness of the GUI) a 7020 SFF is still a more than decent machine, you won't have issues with it.
Thanks for the link, that was not available when I did mine, seems like an easier way to go.
I bought basically the same thing overseas and then wiped the firmware with the one from the discord channel links, nice to have everything already setup, as the rest of the install is more complicated.
Regarding the coolers, it looks like the USB one is a complete solution. The other ones seem to rely on the person having a 3D printer?
