That's why I suggested using MikroTik Configurator – eXtreme Hosting, what it configures "by default" is reasonably good. And you can can click on things in the "Advanced" part and immediately see what it does by looking at the "live preview" configuration.
Here's an example from when chosing "single device", RB5009, starting in Wizard and selecting Office with vlans, then switching to "Advance mode" and selecting the Firewall section.
Note that by default it allows pings from the internet (to please @anav ), but it is easy to toggle it on and off. In my opinion, responding to pings on the WAN side is like turning on your porch light on Halloween, there are advantages and disadvantages, depending on whether you want to have more people pressing your doorbell.
The configuration tool also by default will block invalid global addresses from ingressing on your WAN interface (Drop bogons and spoofing from WAN in /ip firewall raw). I disable this when I am using a lab router behing my primary internet router, otherwise it won't work, (I have only a single global ip address, so my lab router gets a private ip address on its WAN side).
If you like video tutorials, MikroTik has a youtube channel and Normis recorded a video
MikroTips: How to firewall that is worth watching, as it discusses the basics and goes over the defconf firewall. But it is not an indepth explanation, it is more a quick overview of what is in the firewall you get with the defconf on a SOHO router (like the RB5009).
After you have watched the previous video, if you want a more indepth tutorial, Wilmer Almazan / Arawi Network Consulting has a MikroTik Firewall playlist on his TheNetworkTrip youtube channel, and the first 2 are a good intro that goes into enough depth that it is useful. NOTE WELL: In these videos Wilmer is not using the "defconf" firewall, he is starting from a
/system/reset-configuration no-defaults=yes keep-users=yes skip-backup=yes
state. I do not recommend starting from scratch unless you are working in a lab environment, especially if you are learning. However, if you want to understand what the MikroTik ROS firewall can do and what it cannot do, this is a good starting point.
If that's the case, I would consider getting a small mikrotik router you can play with behind your main rounter. If you want something that could be used as a backup for your RB5009 (with SFP) there is the hEX S 2025 (E60iUGS) and the L009 (if you want a better switch and a built in serial console port). The U60iUGS has some quirks with the ether1 interface, but has much more flash and RAM than the hEX S RB760iGS. If an SFP isn't a requirement (I don't see an SFP+ on the BGW620), then an hap ax 2 may be a better router for a bit more money, or the hap ax lite if you want a smaller device. Any would be a good lab router.
