Adding a LAN Static IP box to a DHCP configured LAN
tldr; I am having trouble getting DNS to work from a device with a static IP, attached to a MikroTik router set up for DHCP.
I am new to MikroTik and RouterOS, but have some experience configuring networks.
I need to configure a small network using a few industrial devices that do not support DHCP, and are set to static IPs in the range 192.168.0.1 - 192.168.0.100.
These devices are all connected to a RB760iGS. and can talk to eachother by IP. I also have a laptop on the network that I use to configure the devices.
The laptop is set up to use DHCP and can use the internet without issues. The devices can ping outside, (8.8.8.8) but cannot resolve any names.
I have a RB760iGS set up as a router starting with the default configuration. I used the quick set web config to set a new IP (192.168.0.1) and DHCP range (192.168.0.100-254).
Internet from another router is connected to Port1, the laptop to 2. In my current configuration there is only one device, on port 4 that I use to debug this problem.
The other router is also providing NAT, on 192.168.4.x; I do not have control over that router, just a wire from it.
Reading through this forum I looked at NAT and Firewall settings. There are a lot of recommendations and videos suggesting using the DHCP server to set a static DHCP lease, but my devices do not support DHCP, so a static IP must be set on the client. I tried adding a static DHCP lease for the devices MAC to no avail.
Since they can ping google, it appears to be a DNS configuration setting:
ping:
had@som:~$ ping 8.8.4.4
PING 8.8.4.4 (8.8.4.4) 56(84) bytes of data.
64 bytes from 8.8.4.4: icmp_seq=1 ttl=119 time=19.1 ms
64 bytes from 8.8.4.4: icmp_seq=2 ttl=119 time=19.3 ms
64 bytes from 8.8.4.4: icmp_seq=3 ttl=119 time=20.6 ms
^C
--- 8.8.4.4 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2004ms
rtt min/avg/max/mdev = 19.101/19.640/20.553/0.648 ms
wget of a google IP:
had@som:~$ wget 216.58.193.68
--2020-09-22 00:17:06--  http://216.58.193.68/
Connecting to 216.58.193.68:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
--2020-09-22 00:17:06--  http://www.google.com/
Resolving www.google.com (www.google.com)... failed: Temporary failure in name resolution.
wget: unable to resolve host address ‘www.google.com’
If someone could give me a pointer to what setting to try to get my static IP clients to resolve addresses, that would be much appreciated.
My config:
[admin@MikroTik] > /export
# sep/21/2020 23:58:17 by RouterOS 6.46.6
# software id = Z48L-LHSM
# model = RB760iGS
add admin-mac=48:8F:5A:6A:35:D9 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.0.1/24 comment=defconf interface=ether2 network=192.168.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.0.24 mac-address=4C:38:D5:11:AD:74
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=America/Boise
/tool mac-server
/tool mac-server mac-winbox
If your devices are statically set, then there’s nothing you can do about resolving DNS names on router itself. You have to configure end devices with IP address of DNS server to use. You could enter IP address of your router as DNS server, (almost) everything is set up to allow that.
There’s a tiny problem which may or may not break some things for you:
Router’s LAN IP address should rather be configured on bridge interface …
Thanks for your response. Explicitly setting the DNS on the static client to the router IP made it work.
For some reason I thought the client would use it’s default gateway implicitly, but that is not the case.
Problem solved, many thanks.
