This sounded so strange to me that (resisting the urge to just dismiss the idea,) I did my own measurements.
The setup:
hAP ax2 on 7.25.2 (stable)
synthetic routed traffic, 512 byte udp packets, 50 kpps
To an empty firewall, with connection tracking turned on, I added the following rule (this rule matches the generated traffic):
/ip firewall mangle add chain=prerouting dst-address=192.168.80.3 action=passthrough
Then I replaced it with this:
/ip firewall mangle add chain=prerouting dst-address=192.168.80.3 action=mark-packet new-packet-mark=mymark
With passthrough the profile shows:
firewall 3 7%
cpu3 77%
with mark-packet it shows:
firewall 3 6.5%
cpu3 74.5%
(of course the measurements jump around quite a bit.)
This makes sense considering that the packet is accompanied by a metadata struct during its travels through the firewall, which is allocated when it first enters it. This struct has the packet mark field allocated and set to the value corresponding to no-mark. When a mark-routing action is executed, the packet is not copied and no new metadata structures get allocated, the already allocated packet-mark field is merely updated to the new value.
What could actually be done is to make the connection mark available as a matched field in the queue, since this could be made available even when the packet is travelling in fasttrack.("could", as in: this isn't currently implemented, but possibly could be in the future.) is
