Free List Conversion Tool for Mikrotik Routers
I’m excited to share a free web tool designed to convert block lists (such as those from AdGuard and traditional hosts files) into a format that’s easy to integrate with Mikrotik routers.
The tool is available at: https://listapp.linuxiarz.pl/.
Key Features
List Conversion:
The tool converts standard hosts or AdGuard block lists by replacing the original IP addresses with a target IP you specify.
This makes it simple to prepare lists that can be directly imported into Mikrotik’s DNS address lists.
Flexible Input Options:
Simply provide a URL pointing to a list (either in classic hosts file format or the AdGuard format), and the tool will normalize and convert the entries for you.
Real-Time Processing:
The conversion happens instantly in your browser, outputting plain text that you can easily copy and paste into your Mikrotik configuration.
Examples of Use
Converting an AdGuard Block List
Suppose you have an AdGuard block list with entries like:
||example.com^
||ads.example.net^
Converting a Classic Hosts File
If your hosts file looks like:
0.0.0.0 example.com
0.0.0.0 ads.example.net
Feel free to check out the tool at https://listapp.linuxiarz.pl/ and share your feedback.
This free tool is ideal for administrators who need a quick and easy way to convert ad-block lists for use in Mikrotik routers.
