I understand MikroTik don’t have plans to incorporate an xDSL module into their products, however the reality is that ADSL and VDSL2 (FTTB/FTTN) is commonly found here in Australia. The MikroTik make the perfect CPE in many cases, but having another device attached to it makes it a less than elegant solution.
As someone learning about IP / routing etc, and also looking into purchasing a Mikrotik/RouterBoard product and living in Australia where i’m due to have VDSL2 available in a few weeks i am very interested in this.
We bought 3 pieces and made first tries with our VDSL lines.
We’ve tried with a RB962UiGS-5HacT2HnT and 3 VDSL configurations:
VDSL2 Vectoriezd 1,5 km
VDSL2 1,8 km
VDSL annex B, 600m
The SFP Modem is good and stable and snr are comparable even better than our current planet VC-231.
The mikrotik router doesn’t recognise the SFP and we have to setup manually the negociation.
We are not able to use it for our customer for the moment because after reboot, it’s impossible to communicate with the SFP module. We need to unplug and plugin the SFP to be able to communicate again.
Will mikrotik support correctly thoses SFP modules soon or not ? It’s really better to have only 1 device at the customers places
In Brazil the most adopted technology for the internet is ADSL and VDSL I do not understand why Mikrotik does not develop solutions with these technologies.
The link that you provide is the dead link. But you can have a look at the monoprice, I have bought several sfp optics from them, and all functioned well!
In Switzerland also most of the lines are VDSL, only 10 percent of fiber-to-home in the major cities…
If we have a ADSL/VDSL interface for Mikrotik, we need more than 300 pieces for our own use and remove all those bridges !
Directly at metanoia, they send us 3 samples… But metonoia support could not help us at the moment…
Our national operator is deploying Gfast and metanoia has also a Gfast module, would be great to be supported soon…
Yes, it should be possible. I looked at those a while back but they’re not certified with the Australian NBN (and all the Australian distributors recently stopped selling Planet gear) so I generally use the Draytek Vigor 130 as a VDSL bridge. I use the Proscend SFP module at home but won’t sell it to my clients.
Are you using Proscend SFP module for your VDSL2 home connection?
Can you establish a PPPoE connection with your ISP?
Does have Mikrotik this features?
