I’m using the NTP server : 0\1.pool.ntp.org
lest month my routers accept it - and now they don’t. (also I don’t have ping from the router to the NTP server - the router is connected to the internet and it’s working)
I have try to use asia/europe.pool.ntp.org - still not working.
What could be the problem?
can it be that my cellular provider (I’m connected to the internet using SIM) change something?
try to set this setting again. pool.ntp.org uses balancing and if you have different server assigned then you have to force-update NTP server entry because FQDN is not accepted as a setting but resovled IP address is, if FQDN is used, then that is resolved immediately and IP address of the result is used when ballacned assigns you to different IP address that is not automatically updated to new IP.
