Thanks for the info but I read that feature and it seems to only work with two seperate routers. Atleast thats what I understood from the examples. Has anyone tried this before? Well to bond to ISPs WAN on the same router?
Example"
Wan 1 = DSL 1.5m Wan2= Cable=3m
Now have two etherner cards with this WANs and bond them together to get 4m output. This all be done on one single router.
As far as I know this only works if your ISP supports multilink and usually uses 2 pppoe connections to bond together. I dont think MT supports this config. It usually requires special hardware. Check out the Planet XRT 402 and XRT 204 for some cheap options
We do that with some sweet code on a Linux box. We have one main server at the colo and each customer has a client server at their location. to date we have a mix of different wan connection bonded. (4 ADSL 256x1.5) (3 ADSL 256x1.5 + 1 ADSL 384x3.5) (2 ADSL 256x1.5 + 1 isdn 128k) (1 cable 5.0 + 1 T1 1.5) (2 ADSL 384x3.5 + 1 cable 5.0)
The biggest seller is 3 or 4 384x3.5 ADSL lines.
Look at like this, We can give them 4 local phone lines for faxing, local calls 911 and backup/ VoIP for long distance / Internet 1.5 up X 14.0 down / Lots of IPs / and all for 600.00 a month which they would pay for a T1 line.
Great info. I understand the Voip, Inet, but how do you furnish the local pots lines? Do you have to make an agreement with your local telco for the stripped down line?
