Did you find the solution? I am having the exact same problem, nmap shows all ports are open and telnet always connects. I am doing this from another internet connection not from inside my local network. I can’t figure out what’s wrong.
UPDATE: Strange but today I checked again and now the ports are not open. Maybe it was some cache issue. No idea.
Here is my configuration:
# dec/20/2023 00:09:15 by RouterOS 7.6
# software id = XXXX-XXX
# model = RBD53G-5HacD2HnD&EG18-EA
# serial number = XXXXXXXXXXXXX
add admin-mac=48:A9:8A:1F:8D:DF auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=latvia disabled=no distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=XXXXXXXX wireless-protocol=802.11 \
wps-mode=push-button-5s
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=latvia disabled=no distance=indoors frequency=\
auto installation=indoor mode=ap-bridge skip-dfs-channels=10min-cac ssid=\
XXXXXXXXXX wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=internet.lmt.lv ipv6-interface=bridge name=\
"LMT Internet" use-network-apn=no
add apn=static1.lmt.lv ip-type=ipv4 name=LMT-static1.lmt.lv
add apn=static2.lmt.lv ip-type=ipv4 name=LMT-static2.lmt.lv
add apn=internet1.lmt.lv ip-type=ipv4 name=LMT-internet1.lmt.lv
add apn=static61.lmt.lv ipv6-interface=bridge name=LMT-static61.lmt.lv
add apn=static62.lmt.lv ipv6-interface=bridge name=LMT-static62.lmt.lv
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=\
LMT-static2.lmt.lv band=""
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=LMT
/ip hotspot profile
add name=dhcp ranges=192.168.8.10-192.168.8.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add comment=defconf interface=lte1 list=WAN
/interface lte settings
set external-antenna=auto
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set enabled=yes
add address=192.168.8.1/24 comment=defconf interface=bridge network=\
192.168.8.0
/ip cloud
set ddns-enabled=yes
add address=192.168.8.0/24 comment=defconf gateway=192.168.8.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.8.1 comment=defconf name=router.lan
add address=212.93.xxx.xxx name=vpn.xxx.xxx
add address=192.168.8.230 name=ssh.xxx.xxx
add address=192.168.8.230 name=server.xxx.xxx
add address=192.168.8.230 disabled=yes name=failiem.xxx.xxx
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
invalid
add action=accept chain=input comment="defconf: accept LMT provisioning" \
dst-port=8081 protocol=tcp src-address=212.93.97.83
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="[Hairpin / Loopback NAT] - Allow t\
o access the home server on public IP address from within LAN" \
dst-address=192.168.8.230 dst-port=80 out-interface=bridge protocol=tcp \
src-address=192.168.8.0/24
add action=dst-nat chain=dstnat comment=\
"80 -> 192.168.8.230 (Cloudflare forwards to port 80)" dst-address=\
212.93.xxx.xxx dst-port=80 protocol=tcp to-addresses=192.168.8.230 \
to-ports=80
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set www-ssl certificate=router.lan
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add local-address=192.168.8.150 name=xxxxxxxxxx profile=default-encryption
add name=vpn profile=default-encryption
/system clock
set time-zone-name=Europe/Riga
/system identity
set name="LMT LTE18"
/system routerboard reset-button
set enabled=yes hold-time=5s..10s on-event=reset-configuration
/system scheduler
add interval=30m name=LMT on-event=lte_reset_script policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-time=startup
/system script
add dont-require-permissions=yes name=reset-configuration owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
"/system reset-configuration"
add dont-require-permissions=yes name=lte_reset_script owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{\
\nlocal counter\
\nlocal ifname\
\nlocal addrese\
\n:if ([:len [interface find where type=\"lte\"]] > 1) do={:set \$ifname [\
interface/get value-name=name number=[find where ifname~\"wwan0.0\"]]} els\
e={\
\n:do {\
\nset \$ifname [interface get value-name=name number=[find where type~\"lt\
e\"]]\
\n} on-error={set \$ifname \"no such item\"}\
\n}\
\n\
\nset \$counter [system/scheduler/get LMT comment]\
\n\
\n:if ([interface/lte/get \$ifname value-name=disabled] = true) do={:error\
\_\"lte disabled\"}\
\n:if (([interface lte monitor lte1 once as-value]->\"status\") = \"sim no\
t present\") do={:error \"sim not present\"}\
\n\
\n:if (\$ifname = \"no such item\") do={:error \"no lte interface\"} else=\
\n:do {\
\nset \$addrese [ip address/get value-name=address number=[find where actu\
al-interface~\"\$ifname\"]]\
\n} on-error={set \$addrese \"no such item\"\
\n}\
\n\
\n:if (\$addrese = \"no such item\") do={\
\n/interface lte disable numbers=\$ifname\
\ndelay 2;\
\n/interface lte enable numbers=\$ifname\
\n:local count 0;\
\n:while ([/interface lte get \$ifname value-name=running] = false) do={\
\n :put \$count\
\n :if (\$count = 60) do={\
\n :if (\$counter = \"10\") do={:error \"already rebooted 10 times\"}\
\n :log error \"LTE not running after disable/enable. Rebooting...\";\
\n :if (\$counter = \"\") do={/system/scheduler/set LMT comment=1} else\
={/system/scheduler/set LMT comment=(\$counter + 1)}\
\n /execute script={/system/reboot};\
\n }\
\n :delay 1s; :set count (\$count +1); \
\n}\
\n:log warning \"LTE running after disable/enable\";\
\n/system/scheduler/set LMT comment=\"\"\
\n} else={/system/scheduler/set LMT comment=\"\"}\
\n}}"
/tool mac-server
/tool mac-server mac-winbox
/tr069-client
set acs-url=https://xxx.lmt.lv:xxxx check-certificate=no \
connection-request-port=8081 connection-request-username=xxxxxxxxxx \
enabled=yes periodic-inform-interval=12h username=LMT
