Dear all,
Please advise how to allow teamviewer traffic to be passed out via the routerboard, because I have already made some configurations through winbox (check attached screenshots) but without result.
Awaiting your reply.
Thank you in advance.
Dear all,
Set dst-address to IP address of router, teamviewer is using for connecion.
Set local IP address of computer running Teamviewer server to to-addresses.
Dear Sir,
Thank you for the aforementioned information. However, I am still not able to use Teamviewer. My current configuration is a Mikrotik RouterBOARD 750 connected directly to a PC. The IPCONFIG gives the below:
Ip address: 192.168.10.20
Default GW:192.168.10.1
As per your instruction, I have set the dst-address column of the firewall rules to 192.168.10.1 (router’s IP) and I have also created a NAT Rule <5938> with the following details:
General Tab
Chain: dstnat
Protocol: 6(tcp)
Dst. Port: 5938
Action
Action: dstnat
To Addresses: 192.168.10.20
To Ports: 5938
Please advise.
Do you have public IP address on RouterBOARD750G?
