Hello all at first !
i recently had some difficulty’s with one problem in work.
There is computer classroom and then there is users who brought own laptops and plug in ethernet cables to get access to internet. How can allow only my computers to be able to connect to internet and dissalow others ?
My first attempt was to setup
- ethernet Interface with ARP: [Reply Only]
- in DHCP: Authoritative: [Yes] Bootp Support [ Static]
and - in DHCP i put Add ARP for Leases
Now this works only problem is it automatically Adds new connections from DHCP to ARP list and if i remove users with laptops from arp list they just replug cable and they are back 3. point ehhhh… ! but if i disable taht point [3. in DHCP Add ARP for Leases]
i lost connection for all computers in network they can’t access internet. I know there is some kind of error in my configuration so can you help me to find out suggestions ? Maybe there is other way how to prevent access to internet for users ?
Thank you guys/girls
