allowing direct access via mikrotik, repost
Hi
I have a Mikrotik RB600A that has been setup to force all traffic through my Squid Cache Proxy. The current connection is: CPE—>mikrotik—>>Squid Proxy—>ADSL modem
I can browse websites fine, but POP3 or any other protocol like online gaming etc does not go through. How do i allow pop3 and online gaming to go directly via the ADSL line?
here is my config
# feb/11/2010 05:45:14 by RouterOS 3.24
# software id = K57N-PTT
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    comment="PPPoE Peak Time" disabled=no forward-delay=15s max-message-age=\
    20s mtu=1500 name=radius1 priority=0x8000 protocol-mode=rstp \
    transmit-hold-count=6
    comment="HotSpot Peak Time" disabled=no forward-delay=15s \
    max-message-age=20s mtu=1500 name=radius2 priority=0x8000 protocol-mode=\
    rstp transmit-hold-count=6
    comment="PPPoE Off-Peak Time" disabled=no forward-delay=15s \
    max-message-age=20s mtu=1500 name=radius3 priority=0x8000 protocol-mode=\
    comment="HotSpot Off-Peak Time" disabled=no forward-delay=15s \
    max-message-age=20s mtu=1500 name=radius4 priority=0x8000 protocol-mode=\
    none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes \
    mac-address=00:0C:42:25:ED:EF mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes \
    mac-address=00:0C:42:25:ED:F0 mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes \
    mac-address=00:0C:42:25:ED:F1 mtu=1500 name=ether3 speed=100Mbps
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
    group-key-update=5m interim-update=0s mode=none name=default \
    radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
    static-sta-private-algo=none static-sta-private-key="" \
    static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
    none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" \
    wpa2-pre-shared-key=""
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
    antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=5ghz \
    basic-rates-a/g=6Mbps burst-time=disabled comment="" compression=no \
    country="united states" default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
    disable-running-check=no disabled=no disconnect-timeout=3s \
    frame-lifetime=0 frequency=5220 frequency-mode=manual-txpower hide-ssid=\
    no hw-retries=4 mac-address=00:0C:42:3A:0B:91 max-station-count=2007 \
    mode=ap-bridge mtu=1500 name="wlan1 (sector1)" noise-floor-threshold=\
    default on-fail-retry-time=100ms periodic-calibration=default \
    periodic-calibration-interval=60 preamble-mode=both \
    proprietary-extensions=post-2.9.25 radio-name=000C423A0B91 rate-set=\
    default scan-list=default security-profile=default ssid=MikroTik \
    station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tx-power-mode=\
    default update-stats-interval=disabled wds-cost-range=50-150 \
    wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
    disabled wmm-support=disabled
set 1 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
    frame-lifetime=0 frequency=5280 frequency-mode=manual-txpower hide-ssid=\
    no hw-retries=4 mac-address=00:0C:42:3A:0A:F2 max-station-count=2007 \
    mode=ap-bridge mtu=1500 name="wlan2 (sector2)" noise-floor-threshold=\
    proprietary-extensions=post-2.9.25 radio-name=000C423A0AF2 rate-set=\
set 2 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
    frame-lifetime=0 frequency=5180 frequency-mode=manual-txpower hide-ssid=\
    no hw-retries=4 mac-address=00:0C:42:3A:1E:51 max-station-count=2007 \
    mode=ap-bridge mtu=1500 name="wlan3 (sector3)" noise-floor-threshold=\
    proprietary-extensions=post-2.9.25 radio-name=000C423A1E51 rate-set=\
set 3 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
    antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2.4ghz-b/g \
    basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment="" \
    compression=no country="south africa" default-ap-tx-limit=0 \
    default-authentication=yes default-client-tx-limit=0 default-forwarding=\
    yes dfs-mode=none disable-running-check=no disabled=yes \
    disconnect-timeout=3s frame-lifetime=0 frequency=2412 frequency-mode=\
    manual-txpower hide-ssid=no hw-retries=4 mac-address=00:0C:42:3A:8B:84 \
    max-station-count=2007 mode=ap-bridge mtu=1500 name="wlan4 (omni)" \
    noise-floor-threshold=default on-fail-retry-time=100ms \
    periodic-calibration=default periodic-calibration-interval=60 \
    preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
    000C423A8B84 rate-set=default scan-list=default security-profile=default \
    ssid=zTelHotspot station-bridge-clone-mac=00:00:00:00:00:00 \
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default \
    update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
    none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
/interface wireless manual-tx-power-table
set "wlan1 (sector1)" comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:1\
    7,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mb\
    ps:17,54Mbps:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20\
    -7:0,HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7\
    :0,HT40-8:0"
set "wlan2 (sector2)" comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:1\
    :0,HT40-8:0"
set "wlan3 (sector3)" comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:1\
    :0,HT40-8:0"
set "wlan4 (omni)" comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,1\
    1Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:\
    17,54Mbps:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:\
    0,HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,\
    HT40-8:0"
/interface wireless nstreme
set "wlan1 (sector1)" comment="" disable-csma=no enable-nstreme=no \
    enable-polling=yes framer-limit=3200 framer-policy=none
set "wlan2 (sector2)" comment="" disable-csma=no enable-nstreme=no \
set "wlan3 (sector3)" comment="" disable-csma=no enable-nstreme=no \
set "wlan4 (omni)" comment="" disable-csma=no enable-nstreme=no \
/ip firewall layer7-protocol
add comment="" name=sip regexp="^(invite|register|cancel|message|subscribe|not\
    ify) sip[\\x09-\\x0d -~]*sip/[0-2]\\.[0-9]"
add comment="" name=skypetoskype regexp="^..\\x02............."
add comment="" name=h323 regexp=\
    "^\\x03..\?\\x08...\?.\?.\?.\?.\?.\?.\?.\?.\?.\?.\?.\?.\?.\?.\?\\x05"
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
    http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
    name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=no
add dns-name="" hotspot-address=192.168.19.1 html-directory=hotspot \
    name=hsprof1 nas-port-type=wireless-802.11 radius-accounting=yes \
    radius-default-domain="" radius-interim-update=received \
    radius-location-id="" radius-location-name="" radius-mac-format=\
    XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=yes
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=\
    1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m \
    name=default pfs-group=modp1024
add name=pool1 ranges=192.168.16.2-192.168.16.254
add name=pool2 ranges=192.168.17.2-192.168.17.254
add name=pool3 ranges=192.168.18.2-192.168.18.254
add name=hs-pool-7 ranges=192.168.19.2-192.168.19.254
add address-pool=hs-pool-7 authoritative=after-2sec-delay bootp-support=\
    static disabled=no interface="wlan4 (omni)" lease-time=1h name=dhcp1
/ip hotspot
add address-pool=hs-pool-7 addresses-per-mac=2 disabled=no idle-timeout=5m \
    interface="wlan4 (omni)" keepalive-timeout=none name=hotspot1 profile=\
    hsprof1
/port
set 0 baud-rate=115200 data-bits=8 flow-control=hardware name=serial0 parity=\
    none stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default \
    use-compression=default use-encryption=default use-vj-compression=default
add change-tcp-mss=yes comment="" local-address=192.168.16.1 name=default1 \
    only-one=default remote-address=pool1 use-compression=default \
add change-tcp-mss=yes comment="" local-address=192.168.17.1 name=default2 \
    only-one=default remote-address=pool2 use-compression=default \
add change-tcp-mss=yes comment="" local-address=192.168.18.1 name=default3 \
    only-one=default remote-address=pool3 use-compression=default \
set default-encryption change-tcp-mss=yes comment="" name=default-encryption \
    only-one=default use-compression=default use-encryption=yes \
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
    sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
    red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
    5
add kind=pcq name=PCQ_Upload pcq-classifier=src-address pcq-limit=50 \
    pcq-rate=0 pcq-total-limit=2000
add kind=pcq name=PCQ_Download pcq-classifier=dst-address pcq-limit=50 \
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" \
    direction=both disabled=no dst-address=0.0.0.0/0 interface=all limit-at=\
    0/0 max-limit=0/0 name="Equal Sharing Queue" parent=none priority=8 \
    queue=PCQ_Upload/PCQ_Download target-addresses=192.168.16.0/22 \
    total-queue=default
    direction=both disabled=yes dst-address=0.0.0.0/0 limit-at=64k/128k \
    max-limit=64k/128k name=mustafa1limit parent=none priority=8 queue=\
    default-small/default-small total-queue=default-small
    direction=both disabled=yes dst-address=0.0.0.0/0 interface=all limit-at=\
    20k/24k max-limit=20k/24k name=queue1 parent=none priority=8 queue=\
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
    max-limit=0 name=main.queue.in packet-mark="" parent=global-in priority=8 \
    queue=default
    max-limit=0 name=main.queue.out packet-mark="" parent=global-out \
    priority=8 queue=default
    max-limit=0 name="Incoming Priority Level 1" packet-mark=L1-data parent=\
    main.queue.in priority=1 queue=default
    max-limit=0 name="Incoming Priority Level 2" packet-mark=L2-data parent=\
    main.queue.in priority=2 queue=default
    max-limit=0 name="Incoming Priority Level 3" packet-mark=L3-data parent=\
    main.queue.in priority=3 queue=default
    max-limit=0 name="Incoming Priority Level 4" packet-mark=L4-data parent=\
    main.queue.in priority=4 queue=default
    max-limit=0 name="Incoming Priority Level 5" packet-mark=L5-data parent=\
    main.queue.in priority=5 queue=default
    max-limit=0 name="Incoming Priority Level 6" packet-mark=L6-data parent=\
    main.queue.in priority=6 queue=default
    max-limit=0 name="Incoming Priority Level 7" packet-mark=L7-data parent=\
    main.queue.in priority=7 queue=default
    max-limit=0 name="Incoming Priority Level 8" packet-mark=L8-data parent=\
    main.queue.in priority=8 queue=default
    max-limit=0 name="Outgoing Priority Level 1" packet-mark=L1-data parent=\
    main.queue.out priority=1 queue=default
    max-limit=0 name="Outgoing Priority Level 2" packet-mark=L2-data parent=\
    main.queue.out priority=2 queue=default
    max-limit=0 name="Outgoing Priority Level 3" packet-mark=L3-data parent=\
    main.queue.out priority=3 queue=default
    max-limit=0 name="Outgoing Priority Level 4" packet-mark=L4-data parent=\
    main.queue.out priority=4 queue=default
    max-limit=0 name="Outgoing Priority Level 5" packet-mark=L4-data parent=\
    max-limit=0 name="Outgoing Priority Level 6" packet-mark=L6-data parent=\
    main.queue.out priority=6 queue=default
    max-limit=0 name="Outgoing Priority Level 7" packet-mark=L7-data parent=\
    main.queue.out priority=7 queue=default
    max-limit=0 name="Outgoing Priority Level 8" packet-mark=L8-data parent=\
    main.queue.out priority=8 queue=default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0
/routing ospf area
add area-id=0.0.0.0 authentication=none disabled=no name=backbone type=\
    default
/snmp
set contact="" enabled=no engine-boots=0 engine-id="" location="" \
    time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=\
    DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
/user group
add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass\
    word,web,sniff,!ftp,!write,!policy"
add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb\
    ox,password,web,sniff,!ftp,!policy"
add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy\
    ,test,winbox,password,web,sniff"
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
/interface ethernet mirror
set
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:03:72:A5:57:72 \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pppoe-server server
add authentication=pap,chap,mschap1,mschap2 default-profile=default1 \
    disabled=no interface="wlan1 (sector1)" keepalive-timeout=10 max-mru=1480 \
    max-mtu=1480 max-sessions=0 mrru=disabled one-session-per-host=yes \
    service-name=service1
add authentication=pap,chap,mschap1,mschap2 default-profile=default2 \
    disabled=no interface="wlan2 (sector2)" keepalive-timeout=10 max-mru=1480 \
    service-name=service2
add authentication=pap,chap,mschap1,mschap2 default-profile=default3 \
    disabled=no interface="wlan3 (sector3)" keepalive-timeout=10 max-mru=1480 \
    service-name=service3
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
    no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.0.0.50/24 broadcast=10.0.0.255 comment="" disabled=no \
    interface=ether3 network=10.0.0.0
add address=192.168.19.1/24 broadcast=192.168.19.255 comment=\
    "hotspot network" disabled=no interface="wlan4 (omni)" network=\
    192.168.19.0
add address=192.168.0.1/32 broadcast=192.168.0.1 comment="" disabled=no \
    interface=radius1 network=192.168.0.1
add address=192.168.0.2/32 broadcast=192.168.0.2 comment="" disabled=no \
    interface=radius2 network=192.168.0.2
add address=192.168.0.3/32 broadcast=192.168.0.3 comment="" disabled=no \
    interface=radius3 network=192.168.0.3
add address=192.168.0.4/32 broadcast=192.168.0.4 comment="" disabled=no \
    interface=radius4 network=192.168.0.4
/ip dhcp-server config
set store-leases-disk=5m
add address=10.5.50.0/24 comment="hotspot network" gateway=10.5.50.1
add address=192.168.16.0/24 comment="" gateway=192.168.16.1
add address=192.168.19.0/24 comment="hotspot network" gateway=192.168.19.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=4096KiB \
    max-udp-packet-size=512 primary-dns=10.240.12.7 secondary-dns=\
    196.34.27.137
/ip firewall address-list
add address=192.168.16.0/24 comment="" disabled=no list=Sector
add address=192.168.17.0/24 comment="" disabled=no list=Sector
add address=192.168.18.0/24 comment="" disabled=no list=Sector
add address=10.0.0.0/24 comment="" disabled=no list=Sector
add address=192.168.19.0/24 comment="" disabled=no list=Sector
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=forward comment="" disabled=yes out-interface=ether3
add action=accept chain=forward comment="" disabled=yes out-interface=ether3 \
    protocol=udp
    protocol=tcp
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
/ip firewall mangle
add action=mark-connection chain=forward comment="Winbox Connection Marking" \
    disabled=no dst-port=8291 new-connection-mark=L1-conn passthrough=yes \
    protocol=tcp
add action=mark-packet chain=forward comment=\
    "Priority Level 1 Packet Marking" connection-mark=L1-conn disabled=no \
    new-packet-mark=L1-data passthrough=no
add action=mark-connection chain=forward comment="VoIP Connection Marking" \
    disabled=no layer7-protocol=sip new-connection-mark=L2-conn passthrough=\
    yes
add action=mark-connection chain=forward comment="" disabled=no \
    layer7-protocol=skypetoskype new-connection-mark=L2-conn passthrough=yes
    layer7-protocol=h323 new-connection-mark=L2-conn passthrough=yes
    "Priority Level 2 Packet Marking" connection-mark=L2-conn disabled=no \
    new-packet-mark=L2-data passthrough=no
    "Priority Level 3 Packet Marking" connection-mark=L3-conn disabled=no \
    new-packet-mark=L3-data passthrough=no
add action=mark-connection chain=forward comment="Web Connection Marking" \
    disabled=no dst-port=80,443 new-connection-mark=L4-conn passthrough=yes \
    protocol=tcp
    "Priority Level 4 Packet Marking" connection-mark=L4-conn disabled=no \
    new-packet-mark=L4-data passthrough=no
    "Priority Level 5 Packet Marking" connection-mark=L4-conn disabled=no \
    new-packet-mark=L5-data passthrough=no
add action=mark-connection chain=forward comment="Email Connection Marking" \
    disabled=no dst-port=25,110,143 new-connection-mark=L6-conn passthrough=\
    yes protocol=tcp
    "Priority Level 6 Packet Marking" connection-mark=L6-conn disabled=no \
    new-packet-mark=L6-data passthrough=no
add action=mark-connection chain=forward comment="FTP Connection Marking" \
    disabled=no dst-port=21 new-connection-mark=L7-conn passthrough=yes \
    protocol=tcp
    "Priority Level 7 Packet Marking" connection-mark=L7-conn disabled=no \
    new-packet-mark=L7-data passthrough=no
add action=mark-connection chain=forward comment=\
    "Other Traffic Connection Marking" disabled=no new-connection-mark=\
    L8-conn passthrough=yes
    "Priority Level 8 Packet Marking" connection-mark=L8-conn disabled=no \
    new-packet-mark=L8-data passthrough=no
add action=masquerade chain=srcnat comment="" disabled=no out-interface=\
    ether3
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
    disabled=no src-address=192.168.19.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip hotspot user
add comment="" disabled=no name=admin password=admin profile=default
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set "wlan1 (sector1)" discover=no
set "wlan2 (sector2)" discover=no
set "wlan3 (sector3)" discover=no
set "wlan4 (omni)" discover=no
set radius1 discover=yes
set radius2 discover=yes
set radius3 discover=yes
set radius4 discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.0.0.2 \
    scope=30 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=yes show-dummy-rule=yes
/ppp aaa
set accounting=yes interim-update=0s use-radius=yes
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set "wlan1 (sector1)" queue=wireless-default
set "wlan2 (sector2)" queue=wireless-default
set "wlan3 (sector3)" queue=wireless-default
set "wlan4 (omni)" queue=wireless-default
set radius1 queue=default
set radius2 queue=default
set radius3 queue=default
set radius4 queue=default
/radius
add accounting-backup=no accounting-port=1813 address=192.168.0.2 \
    authentication-port=1812 called-id="" comment="" disabled=no domain="" \
    realm="" secret=123456 service=hotspot timeout=300ms
add accounting-backup=no accounting-port=1813 address=192.168.0.4 \
    realm="" secret=654321 service=hotspot timeout=300ms
add accounting-backup=no accounting-port=1813 address=192.168.0.1 \
    realm="" secret=123456 service=ppp timeout=300ms
add accounting-backup=no accounting-port=1813 address=192.168.0.3 \
    realm="" secret=654321 service="" timeout=300ms
/radius incoming
set accept=no port=3799
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing ospf
set distribute-default=never metric-bgp=20 metric-connected=20 \
    metric-default=1 metric-rip=20 metric-static=20 mpls-te-area=unspecified \
    mpls-te-router-id=unspecified redistribute-bgp=no redistribute-connected=\
    no redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=user-manager1 type=user-manager
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=Africa/Johannesburg
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set fan-mode=auto use-fan=main
/system identity
set name="zTel Internet"
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=196.4.160.4 secondary-ntp=196.26.5.8
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
    boot-protocol=bootp enable-jumper-reset=yes enter-setup-on=any-key \
    force-backup-booter=no
/system scheduler
add comment="" disabled=no interval=1w name="Peak Time (monday)" on-event=\
    "/system script run peak" policy=\
    reboot,read,write,policy,test,password,sniff start-date=jul/20/2009 \
    start-time=08:00:00
add comment="" disabled=no interval=1w name="Peak Time (tuesday)" on-event=\
    reboot,read,write,policy,test,password,sniff start-date=jul/21/2009 \
    start-time=08:00:00
add comment="" disabled=no interval=1w name="Peak Time (wednesday)" on-event=\
    reboot,read,write,policy,test,password,sniff start-date=jul/22/2009 \
    start-time=08:00:00
add comment="" disabled=no interval=1w name="Peak Time (thursday)" on-event=\
    reboot,read,write,policy,test,password,sniff start-date=jul/23/2009 \
    start-time=08:00:00
add comment="" disabled=no interval=1w name="Peak Time (friday)" on-event=\
    reboot,read,write,policy,test,password,sniff start-date=jul/24/2009 \
    start-time=08:00:00
add comment="" disabled=no interval=1w name="Off Peak Time (monday)" \
    on-event="/system script run offpeak" policy=\
    start-time=20:00:00
add comment="" disabled=no interval=1w name="Off Peak Time (tuesday)" \
    start-time=20:00:00
add comment="" disabled=no interval=1w name="Off Peak Time (wednesday)" \
    start-time=20:00:00
add comment="" disabled=no interval=1w name="Off Peak Time (thursday)" \
    start-time=20:00:00
add comment="" disabled=no interval=1w name="Off Peak Time (friday)" \
    start-time=20:00:00
add comment="Peak script run" disabled=yes interval=1d name=Peak on-event=\
    reboot,read,write,policy,test,password,sniff start-date=jan/01/1970 \
    start-time=08:00:00
add comment="Offpeak script run" disabled=yes interval=1d name=Offpeak \
    start-time=20:00:00
/system script
add name=peak policy=ftp,reboot,read,write,policy,test,winbox,password,sniff \
    source="/ip hotspot\r\
    \ndisable hotspot1\r\
    \nenable hotspot1\r\
    \n\r\
    \n/interface pppoe-server server\r\
    \ndisable 0,1,2\r\
    \nenable 0,1,2\r\
    \n\r\
    \n/tool user-manager router\r\
    \nset [find subscriber=\"Night\"] disabled=yes\r\
    \nset [find subscriber=\"Day\"] disabled=no\r\
    \nset [find subscriber=\"HSNight\"] disabled=yes\r\
    \nset [find subscriber=\"HSDay\"] disabled=no\r\
    \n"
add name=offpeak policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff source="/ip hotspo\
    t\r\
    \n\r\
    \ndisable 0,1,2\r\
    \nenable 0,1,2\r\
    \n\r\
    \nset [find subscriber=\"Day\"] disabled=yes\r\
    \nset [find subscriber=\"Night\"] disabled=no\r\
    \nset [find subscriber=\"HSDay\"] disabled=yes\r\
    \nset [find subscriber=\"HSNight\"] disabled=no\r\
    \n"
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=10
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" keep-max-sms=0 reader-running=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
    filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=\
    yes interface=all memory-limit=10 only-headers=no streaming-enabled=no \
/tool user-manager customer
add comment="" disabled=no login=admin parent=admin password="" \
    paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
    permissions=owner signup-allowed=no subscriber=admin time-zone=+00:00
add comment="" disabled=no login=Day parent=Day password=qwerty \
    permissions=owner signup-allowed=no subscriber=Day time-zone=+00:00
add comment="" disabled=no login=Night parent=Night password=qwerty \
    permissions=owner signup-allowed=no subscriber=Night time-zone=+00:00
add comment="" disabled=no login=HSDay parent=HSDay password=qwerty \
    permissions=owner signup-allowed=no subscriber=HSDay time-zone=+00:00
add comment="" disabled=no login=HSNight parent=HSNight password=qwerty \
    permissions=owner signup-allowed=no subscriber=HSNight time-zone=+00:00
add comment="" disabled=yes ip-address=192.168.0.1 log=\
    auth-ok,auth-fail,acct-fail name=router1 shared-secret=123456 subscriber=\
    Day
add comment="" disabled=no ip-address=192.168.0.3 log=\
    auth-ok,auth-fail,acct-fail name=router1 shared-secret=654321 subscriber=\
    Night
add comment="" disabled=yes ip-address=192.168.0.2 log=\
    HSDay
add comment="" disabled=no ip-address=192.168.0.4 log=\
    HSNight
/tool user-manager user
----User data was here---
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
I do not see reason, why POP3 should not go through the router with current configuration.
You cant forcibly redirect non http traffic to a proxy. The customers would have to specify the proxy and the application would have to be proxy aware..
thanks for the reply.. but it doesnt go through, i could send you my backup file if you will be willing to check please
Then maybe all other traffic is blocked? because no other traffic is able to go through, i’m struggling with this for around 6 months now
