Is it posibile to implement some kind of Alt+TAB inside of Winbox. When U open many windows it is hard do get to the right one without closing oder windows… Thanx…
alt tab will stwitch to another program outside winbox. but thanks for the idea, we will think about some solution
Hi there,
Within Windows applications, it’s “Control-Tab” which switches between tabs in a tabbed-dialogue box (and a few other cases I think).
Should be possible to incorporate that into Winbox.
Regards
Actually it’s working exactly this way - at least in windows which have several tabs (e.g. “Users”).
So there has to be another shortcut if they want to implement this… Something like Shift-Tab or the like…
Would be best to show a list of windows you switch through like Windows does in the middle of the screen while using Alt-Tab.
