Android App Developer
Hello everyone,
Please, I need a software developer here who can help me build an MikroTik Android App that I can use to update my MikroTik Router user details only.
A small Android App like MikroTik Mobile App.
Please contact me via email (davidolaj @ gmail.com) if you can build the App.
you can always create a skin that only allows you to access the user manager and modify or insert users
did you figure that out? Check out different platforms like Upwork and Fiverr; you might have better luck finding opportunities there. These sites offer a variety of freelance gigs that can help you gain experience and build your portfolio. Additionally, another effective approach is to focus on improving your skills continuously. There are plenty of free resources available that can help you along the way. Understanding how to work with strings is crucial for web development, as it allows you to handle data more effectively. As you enhance your coding abilities, you’ll become more confident and capable of tackling different projects. Combining practical experience from platforms like Upwork or Fiverr with solid foundational knowledge will undoubtedly boost your chances of success. Keep pushing yourself, and remember that each step you take brings you closer to your goals
You can consider reaching out to freelance platforms like Upwork or Fiverr to find a developer with experience in MikroTik API and Android development. You might also want to check the MikroTik forum for developers who specialize in similar projects. Good luck with your app!
