I’ve searched many threads on port forwarding, but this one still has me very confused.
MT router has WAN interface with public IP P.P.P.P (ppoe connection to aDSL modem in bridge mode)
LAN has L.L.L.L/24, with a DHCP range of L.L.L.100 - L.L.L.150
A static IP address is allocated to a machine at L.L.L.10, this machine connects to a remote service on the internet using port 5545.
I have a universal “masquerade” rule in NAT that allows local devices to connect to the WAN/Internet, and this works fine. I have set a rule in NAT to allow the outside service to connect to L.L.L.10 via port 5545:
I can see traffic coming in from the remote server (using Torch) but the responses from the local device get lost somewhere. When I use the MT packet sniffer, I see the response packets from the local device, but they do not make it to the WAN interface for some reason.
It seems to be correct with Mikrotik configuration although you must export all firewall, IP address, Interface and routes configuration too.
Are you sure about your Local PC and it’s firewall?
If this PC has other services like IIS, try to test it via port 80.
0 A S 0.0.0.0/0 isp 1
1 ADC ISP Gateway Public IP isp 0
2 A S ;;; Static route to Axxxx server
L.L.1.1/32 192.168.10.2 1
3 A S ;;; Static route to Oxxxxx server
L.L.1.99/32 192.168.10.2 1
4 A S ;;; Static route to Mailserver
L.L.1.100/32 192.168.10.2 1
5 A S ;;; Static route to Axxxxx
L.L.1.134/32 192.168.10.2 1
6 ADC L.L.5.0/24 172.17.5.1 ether5 0
7 ADC 192.168.10.0/30 192.168.10.1 tunnel1 0
Explanation: I have an IPSec tunnel running, local address is 192.168.10.1. All static routes here point to devices at the other end of the tunnel, and all are working normally.
# ADDRESS NETWORK INTERFACE
0 ;;; LAN IP range on ether5
L.L.5.1/24 L.L.5.0 ether5
1 ;;; Near end of IP tunnel
192.168.10.1/30 192.168.10.0 tunnel1
2 D Public IP ISP gateway IP isp
# NAME TYPE MTU L2MTU
0 R ether1 ether 1300 1300
1 ether2 ether 1500 1598
2 ether3 ether 1500 1598
3 ether4 ether 1500 1598
4 R ether5 ether 1500 1598
5 R isp pppoe-out 1300
6 R tunnel1 ipip 1480
There is a single public IP on the WAN interface. I added the above rule to force L.L.5.10 to go out that way (in case something? was causing it to go elsewhere) but it seems to make no difference.
If you want to force, you need to add mangle rule which detect packets from specific IP then mark route. In routes can use routing mark.
BTW, you have 0.0.0.0/0 gateway and the client goes over this for non routed destinations.
I can’t see any problem till now. Try to check the client when got enough permission.
I don’t think I’ll get admin permission on the machine in question. In any case, the machine is responding (see my comment on packet sniffer) but the traffic isn’t getting out of the MT.
Unless I’m missing something basic, I don’t see how mangle rules are necessary for this, but I’ll try it!
I’ve read the mangle wiki several times by now, and still can’t make any sense of it. Can anybody help me? I just need to be started in the right direction.
