i have a problem with ansible:
I wrote some playbooks, that do basic things like getting the routeros version from the mikrotik, and the playbook itself seems to works fine.
What i mean by that is that about half of the mikrotiks (all in one network, all reachbale via ssh, all with the same firewall settings ect) send the information that i requested just fine. But with the other half i get this strange error (see below).
I tested it intensively with two mikrotiks ( RB2011UiAS). I compared the config side by side, other then the ip´s (in the same network) everything is 100% the same. Even the software version. Both are reachable via ssh.
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: ansible.module_utils.connection.ConnectionError: timeout value 10 seconds reached while trying to send command: /system resource print
fatal: [XXX:XXX:XXX:X::XX]: FAILED! => {“changed”: false, “module_stderr”: “Traceback (most recent call last):\n File "/root/.ansible/tmp/ansible-local-22921xL1Zh9/ansible-tmp-1598512873.3-22929-127716503250274/AnsiballZ_routeros_command.py", line 102, in \n _ansiballz_main()\n File "/root/.ansible/tmp/ansible-local-22921xL1Zh9/ansible-tmp-1598512873.3-22929-127716503250274/AnsiballZ_routeros_command.py", line 94, in _ansiballz_main\n invoke_module(zipped_mod, temp_path, ANSIBALLZ_PARAMS)\n File "/root/.ansible/tmp/ansible-local-22921xL1Zh9/ansible-tmp-1598512873.3-22929-127716503250274/AnsiballZ_routeros_command.py", line 40, in invoke_module\n runpy.run_module(mod_name=‘ansible.modules.network.routeros.routeros_command’, init_globals=None, run_name=‘main’, alter_sys=True)\n File "/usr/lib/python2.7/runpy.py", line 188, in run_module\n fname, loader, pkg_name)\n File "/usr/lib/python2.7/runpy.py", line 82, in _run_module_code\n mod_name, mod_fname, mod_loader, pkg_name)\n File "/usr/lib/python2.7/runpy.py", line 72, in _run_code\n exec code in run_globals\n File "/tmp/ansible_routeros_command_payload_VN97ME/ansible_routeros_command_payload.zip/ansible/modules/network/routeros/routeros_command.py", line 187, in \n File "/tmp/ansible_routeros_command_payload_VN97ME/ansible_routeros_command_payload.zip/ansible/modules/network/routeros/routeros_command.py", line 157, in main\n File "/tmp/ansible_routeros_command_payload_VN97ME/ansible_routeros_command_payload.zip/ansible/module_utils/network/routeros/routeros.py", line 125, in run_commands\n File "/tmp/ansible_routeros_command_payload_VN97ME/ansible_routeros_command_payload.zip/ansible/module_utils/network/routeros/routeros.py", line 55, in get_connection\n File "/tmp/ansible_routeros_command_payload_VN97ME/ansible_routeros_command_payload.zip/ansible/module_utils/network/routeros/routeros.py", line 69, in get_capabilities\n File "/tmp/ansible_routeros_command_payload_VN97ME/ansible_routeros_command_payload.zip/ansible/module_utils/connection.py", line 185, in rpc\nansible.module_utils.connection.ConnectionError: timeout value 10 seconds reached while trying to send command: /system resource print\n”, “module_stdout”: “”, “msg”: “MODULE FAILURE\nSee stdout/stderr for the exact error”, “rc”: 1}
(Xed out the ipv6)
Here is the playbook:
- name: Check mikrotik os version
hosts: mikrotik
gather_facts: no
tasks:
- name: CHeck OS
routeros_command:
commands: /system package print
register: version_output
- name: Disply version
debug:
var: version_output
I tried it with another playbook, with mikrotiks with older and brand new firmware, set the timeout to 120 seconds, nothing has worked so far.
I also am aware of the problems that some symboles in the username cause, and thats not the case here.
If anyone has an idea what could cause this problem, i would be more then happy.
