@anav: I replaced my public /24 with 192.0.2/24 and keys/other public IPs/secrets with asterisks.
Not sure how easy to digest this full blown config is but as I said, the gist is:
- ISP (with dynamic IP) is vlan2/FTTH
- Two wireguard tunnels wg-bg1-ftth and wg-bg2-ftth which establish over this FTTH connection over public /31 networks and run OSPF and iBGP.
- Routing rule that handles everything with source address 192.0.2.0/24 in table default_myas. Those default routes are dynamically inserted via iBGP.
- vlan44 with public IP 192.0.2.210/28. This is used as “Wireguard Server”
- The wireguard road warrier interface/peer is wg-mobile/miPhone
- My main issue is that I just don’t get additional debug info (like log entries) but I can assert that ROS does not send wireguard TX packets for wg-mobile at all once both wg-bg1-ftth and wg-bg2-ftth are up (but does so, if wg-bg-ftth is down)
# 2024-11-25 10:54:47 by RouterOS 7.15.3
# software id =
add name=br-main vlan-filtering=yes
add arp=disabled fast-forward=no name=dum0 protocol-mode=none
set [ find default-name=ether1 ] disable-running-check=no
/interface wireguard
add listen-port=13231 mtu=1420 name=wg-bg1-ftth
add listen-port=13232 mtu=1420 name=wg-bg2-ftth
add listen-port=51820 mtu=1420 name=wg-mobile
/interface vlan
add comment=ADM interface=br-main name=vlan1 vlan-id=1
add comment=FTTH interface=br-main name=vlan2 vlan-id=2
add comment=LAN interface=br-main name=vlan3 vlan-id=3
add comment=SRV interface=br-main name=vlan4 vlan-id=4
add comment=ADU interface=br-main name=vlan10 vlan-id=10
add comment=DEV interface=br-main name=vlan11 vlan-id=11
add comment=DEVP interface=br-main name=vlan12 vlan-id=12
add comment=DMZ44 interface=br-main name=vlan44 vlan-id=44
/interface vrrp
add interface=vlan1 name=vrrp1
add interface=vlan3 name=vrrp3 sync-connection-tracking=yes vrid=3
add interface=vlan4 name=vrrp4 vrid=4
add interface=vlan11 name=vrrp11 vrid=11
add interface=vlan12 name=vrrp12 vrid=12
add interface=vlan44 name=vrrp44 vrid=44
add name=LAN
add comment="Admin Interfaces" name=ADM
add name=DMZ
add name=SRV
add name=DEV
add name=DEVP
add name=WAN
add include=ADM,DEV,DEVP,DMZ,LAN,SRV name=trusted
add name=peers
add name=WANMYAS
add name=ISP
add name=MACHINES
/routing ospf instance
add disabled=no name=ospf-instance-1 redistribute=static router-id=192.0.2.210
/routing ospf area
add disabled=no instance=ospf-instance-1 name=ospf-area-1
/routing table
add disabled=no fib name=default_myas
add disabled=no fib name=default_isp
add comment="Dummy table, acts only as a routing mark" disabled=no fib name=default_isp_only
add bridge=br-main interface=ether1
add bridge=br-main interface=veth1 pvid=3
set enabled=yes
set discover-interface-list=none lldp-med-net-policy-vlan=1
/interface bridge vlan
add bridge=br-main tagged=br-main,ether1 vlan-ids=2
add bridge=br-main tagged=br-main,ether1 vlan-ids=3
add bridge=br-main tagged=br-main,ether1 vlan-ids=4
add bridge=br-main tagged=br-main,ether1 vlan-ids=10
add bridge=br-main tagged=br-main,ether1 vlan-ids=11
add bridge=br-main tagged=br-main,ether1 vlan-ids=12
add bridge=br-main tagged=br-main,ether1 vlan-ids=44
add bridge=br-main tagged=br-main untagged=ether1 vlan-ids=1
add bridge=br-main tagged=br-main,ether1 vlan-ids=33
/interface detect-internet
set internet-interface-list=static lan-interface-list=static wan-interface-list=static
add interface=vlan3 list=LAN
add interface=vlan1 list=ADM
add interface=vlan2 list=WAN
add interface=vlan44 list=DMZ
add interface=wg-bg1-ftth list=WAN
add interface=wg-bg2-ftth list=WAN
add interface=vrrp3 list=LAN
add interface=vlan4 list=SRV
add interface=wg-bg1-ftth list=peers
add interface=wg-bg2-ftth list=peers
add interface=vlan11 list=DEV
add interface=vlan12 list=DEVP
add interface=wg-bg1-ftth list=WANMYAS
add interface=wg-bg2-ftth list=WANMYAS
add interface=vlan2 list=ISP
add interface=vlan33 list=ISP
add interface=vlan11 list=MACHINES
add interface=vlan12 list=MACHINES
add interface=vrrp44 list=DMZ
add interface=vrrp1 list=ADM
add interface=vrrp12 list=DEVP
add interface=vrrp4 list=SRV
add interface=vrrp11 list=DEV
add interface=vrrp11 list=MACHINES
add interface=vrrp12 list=MACHINES
/interface wireguard peers
add allowed-address=0.0.0.0/0,::/0 endpoint-address=*.*.*.* endpoint-port=51821 interface=wg-bg2-ftth name=bgate2-ftth persistent-keepalive=5s public-key=“********************************************”
add allowed-address=0.0.0.0/0,::/0 endpoint-address=*.*.*.* endpoint-port=51821 interface=wg-bg1-ftth name=bgate1-ftth persistent-keepalive=5s public-key=“********************************************”
add allowed-address=10.2.33.10/32 client-address=10.2.33.10/32 interface=wg-mobile name=miPhone public-key=“********************************************”
add address=10.2.1.2/24 interface=vlan1 network=10.2.1.0
add address=10.2.4.2/24 interface=vlan4 network=10.2.4.0
add address=10.2.79.2/24 interface=vlan3 network=10.2.79.0
add address=192.0.2.177/31 interface=wg-bg2-ftth network=192.0.2.176
add address=192.0.2.186/29 interface=wg-bg1-ftth network=192.0.2.184
add address=192.0.2.210/28 interface=vlan44 network=192.0.2.208
add address=172.20.215.132 interface=dum0 network=172.20.215.132
add address=10.2.80.2/24 interface=vlan10 network=10.2.80.0
add address=192.168.222.2/24 interface=vlan11 network=192.168.222.0
add address=192.168.223.2/24 interface=vlan12 network=192.168.223.0
add address=10.2.79.254 interface=vrrp3 network=10.2.79.254
add address=10.2.33.1/24 interface=wg-mobile network=10.2.33.0
add address=192.168.223.254 interface=vrrp12 network=192.168.223.254
add address=192.168.222.254 interface=vrrp11 network=192.168.222.254
add address=10.2.1.254 interface=vrrp1 network=10.2.1.254
add address=10.2.4.254 interface=vrrp4 network=10.2.4.254
add address=192.168.5.102/24 interface=vlan33 network=192.168.5.0
add address=192.0.2.222 interface=vrrp44 network=192.0.2.222
/ip dhcp-client
add add-default-route=no interface=vlan2 script=":if (\$bound=1) do={\
\n /ip route set [find where comment=\"default_isp\"] gateway=\$\"gateway-address\" disabled=no\
\n } else={\
\n /ip route set [find where comment=\"default_isp\"] disabled=yes\
\n }\r\
\n\r\
\n" use-peer-ntp=no
/ip firewall address-list
add address=10.2.0.0/16 list=own_hosts
add address=192.0.2.0/24 list=own_hosts
add address=*.*.*.* list=border_gates
add address=*.*.*.* list=own_hosts
add address=192.168.222.0/24 list=own_hosts
add address=192.168.223.0/24 list=own_hosts
add address=172.20.215.128/27 list=own_hosts
add address=0.0.0.0/8 comment="defconf: RFC6890" list=no_forward_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=no_forward_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=no_forward_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=no_forward_ipv4
add address=127.0.0.0/8 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=10.2.0.0/16 list=private_lans
add address=192.168.0.0/16 list=private_lans
add address=172.20.215.128/27 list=border_gates
add address=10.2.4.10 list=hairpin_dst
add address=10.2.4.20 list=hairpin_dst
add address=10.2.0.0/16 list=hairpin_src
add address=192.168.222.0/24 list=hairpin_src
add address=192.168.223.0/24 list=hairpin_src
add action=accept chain=input comment="defconf: accept ICMP after RAW" protocol=icmp
add action=accept chain=input comment="SSH access from everywhere" dst-port=1983 protocol=tcp
add action=accept chain=input comment=Wireguard dst-port=51820 protocol=udp
add action=accept chain=input dst-port=8291 protocol=tcp src-address-list=private_lans
add action=accept chain=input dst-port=3784,4784,3785 in-interface-list=peers protocol=udp src-address-list=own_hosts
add action=accept chain=input in-interface-list=peers protocol=ospf
add action=accept chain=input dst-port=179 in-interface-list=peers protocol=tcp src-address-list=own_hosts
add action=accept chain=input dst-port=53 protocol=udp src-address-list=own_hosts
add action=accept chain=input dst-port=53 protocol=tcp src-address-list=own_hosts
add action=drop chain=input comment="defconf: drop all not coming from trusted" in-interface-list=!trusted
add action=accept chain=forward comment="PortFW: For some reason, Fasttrack doesn't work for these." connection-mark=conn_portfw connection-state=established,related
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=jump chain=forward comment="Traffic rules for new connections" connection-state=new jump-target=traffic_rules
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid log=yes log-prefix=INVALID
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="defconf: drop bad forward IPs" src-address-list=no_forward_ipv4
add action=drop chain=forward comment="defconf: drop bad forward IPs" dst-address-list=no_forward_ipv4
add action=accept chain=forward comment="Check if counters >0. If not, DROP here" log=yes log-prefix="[ACPT]"
add action=accept chain=traffic_rules comment="Allow all ICMP echo" icmp-options=8:0-255 protocol=icmp
add action=accept chain=traffic_rules comment="Allow from ISPs only when DNAT" connection-nat-state=dstnat in-interface-list=ISP
add action=accept chain=traffic_rules comment="Allow internet for public 44" in-interface-list=DMZ out-interface-list=WANMYAS
add action=log chain=traffic_rules comment="Log drops (not wan)" in-interface-list=!WANMYAS log=yes log-prefix="[BLOCKED]" out-interface-list=!WANMYAS src-address=!192.168.222.150
add action=drop chain=traffic_rules
/ip firewall mangle
add action=mark-routing chain=output comment="wg-tunnels: bgate1 over FTTH" dst-address=*.*.*.* dst-port=51821 new-routing-mark=default_isp_only passthrough=no protocol=udp
add action=mark-routing chain=output comment="wg-tunnels: bgate2 over FTTH" dst-address=*.*.*.* dst-port=51821 new-routing-mark=default_isp_only passthrough=no protocol=udp
add action=masquerade chain=srcnat comment="wg-tunnels: FTTH" routing-mark=default_isp_only
add action=masquerade chain=srcnat comment="Hairpin all PortFWs" dst-address-list=hairpin_dst src-address-list=hairpin_src
add action=masquerade chain=srcnat comment="defconf: masquerade WAN interface" out-interface=vlan2
/ip firewall raw
add action=accept chain=prerouting comment="defconf: enable for transparent firewall"
add action=accept chain=prerouting comment="defconf: accept DHCP discover" dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment="defconf: drop forward to local lan from WAN" dst-address-list=private_lans in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop local if not from default IP range" in-interface-list=LAN src-address=!10.2.79.0/24
add action=drop chain=prerouting in-interface-list=DEV src-address=!192.168.222.0/24
add action=drop chain=prerouting in-interface-list=DEVP src-address=!192.168.223.0/24
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 protocol=udp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" jump-target=bad_tcp protocol=tcp
add action=accept chain=prerouting comment="defconf: accept everything else from LAN" in-interface-list=trusted
add action=accept chain=prerouting comment="defconf: accept everything else from WAN" in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" port=0 protocol=tcp
add action=accept chain=icmp4 comment="defconf: echo reply" icmp-options=0:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: net unreachable" icmp-options=3:0 protocol=icmp
add action=accept chain=icmp4 comment="defconf: host unreachable" icmp-options=3:1 protocol=icmp
add action=accept chain=icmp4 comment="defconf: protocol unreachable" icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="defconf: port unreachable" icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 comment="defconf: fragmentation needed" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="defconf: echo" icmp-options=8:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: time exceeded " icmp-options=11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="defconf: drop other icmp" protocol=icmp
add check-gateway=ping comment=default_isp disabled=no distance=1 dst-address=0.0.0.0/0 gateway=*.*.*.* routing-table=default_isp scope=30 suppress-hw-offload=no target-scope=10
/routing bgp connection
add as=64513 disabled=no local.address=172.20.215.132 .role=ibgp name=BorderGate1 remote.address=172.20.215.129/32 .as=64513 routing-table=default_myas
add as=64513 disabled=no local.address=172.20.215.132 .role=ibgp name=BorderGate2 remote.address=172.20.215.130/32 .as=64513 routing-table=default_myas
/routing ospf area range
add area=ospf-area-1 disabled=no prefix=172.20.215.128/27
add area=ospf-area-1 disabled=no prefix=192.0.2.0/24
/routing ospf interface-template
add area=ospf-area-1 auth=md5 auth-id=1 auth-key=**************** cost=100 dead-interval=10s disabled=no hello-interval=5s interfaces=wg-bg1-ftth,wg-bg2-ftth
add area=ospf-area-1 disabled=no interfaces=dum0 passive
add area=ospf-area-1 disabled=no interfaces=vlan44 passive
/routing rule
add action=lookup-only-in-table comment="Connections must never go through other links" disabled=no routing-mark=default_isp_only table=default_isp
add action=lookup comment="main table" disabled=no table=main
add action=lookup comment="default 44net" disabled=no src-address=192.0.2.0/24 table=default_myas
add action=lookup comment="default sonic" disabled=no table=default_isp
/tool sniffer
set filter-ip-address=192.0.2.210/32 filter-ip-protocol=udp filter-port=51820
