ANY HELP BBQ WIFI
Hi all i need a bit of help setting up my BBQ cyber WIFI
I have a Cisco WAP321 wifi hotspot and microtik router.
Have tried to set up http://www.thebbqguru.com/PDF/CyberQ-WiFi-USER-GUIDE.pdf
Can find network but can not join
any ideas on a way around
if you see the SSID that is good. Now check what security options you have to set.
Recommended settings would be WPA2-PSK (for home user) with group/unicast cipher set to AES/CCM as TKIP can misbehave and block authentication for certain time.
