Any news about multiple connections from same IP (L2TP/IPSec)
Hi. Do you have any solution for problem with multiple connections from same IP to VPN via L2TP/IPSec? I read many old posts but answers is like “It will be fixed soon”. I have version 6.35.2 on RouterBOARD 1200 (firmware 3.10).
+1
What exactly you mean? Multiple tunnels from the same client router to the same server?Or mulptiple NATed clients behind the same router?
I believe he’s asking about multiple NATed clients behind the same router.
The problem is well known (I believe) and hurts IPsec in general, not only L2TP/IPsec.
Multiple clients behind NAT is fixed in ROSv7. It is not possible to implement this fix in ROSv6.
Yes. I need mulptiple NATed clients behind the same router.
Ok. Can you tell approximate date of release (maybe devel version) of ROSv7.
Thanks for answer.
in v7 also doesn’t work. when will there be a fix?
