Any One tell Me all Supported miniPci Wireless Card ?
Please anyone send me the list of all wireless supported minipci card which is use in Rb133c And also In x86 Pc based mikrotik
so anyone help me to which card i m use in my mikrotik x86 or in rb133c
you can use 802.11a/b/g cards with Atheros chipset
thanks normis sir
and also i tell u sir one more Questation that if i m using one x86 mikrotik at my base station with using R52 card in AP mode and at client side i use any Atheros chipset base card then i can connect it with 24dbi parabolic antenna
also if LOS is Clear then i can connect client in 10 km radius ?
