Any way to make all hotspot pages SSL.
In testing only the login screen loads up with SSL, status page etc don’t by default. Is there a way to force all hotspot pages to SSL?
Yes, but it’s up to you to edit everything so that the links point to the right protocol in the URI.
but just say someone just types into the browser address bar when they are logged in:
hotspot.myhost.com
Without any protocol info entered by default the page loads non ssl. I didn’t know about anything in the html that controls that, surely it’s the web server that does that? Or maybe you can enlighten me?
Thanks in advance..
I see what you mean now. No, you cannot do that. The built in webserver/servlets don’t support rewrites like that.
You can kind of fudge things out, though. From the manual:
request for “/” on the HotSpot host
  • if user is logged in, rstatus.html is displayed; if rstatus.html is not found, redirect.html is used to redirect to the status page
So you can replace the content of rstatus.html with a meta redirect to https://hotspot.myhotspot.com/real_status.html, and add a file real_status.html to the Hotspot directory. That way, whether the request comes in via HTTPS or HTTP, the user will be redirected to an HTTPS page.
If someone goes to http://hotspot.myhotspot.com/real_status.html that will still load non-SSL, though.
That’s great, thanks. I guess I should have read the manual properly :-0 But you saved me having to do that, and for that I send my thanks :slight_smile:
Set this between the tags of any page you want HTTPS only:
Ex. status.html
$(if server-address == '<router ip>:80')
<meta http-equiv="refresh" content="0; url=https://<router ip>/status">
$(endif)
In my case, my router’s IP is 192.168.101.1 To redirect any http request to https for the status page, here is my status.html:
<html>
<head>
$(if server-address == '192.168.101.1:80')
<meta http-equiv="refresh" content="0; url=https://192.168.101.1/status">
$(endif)
<meta http-equiv="pragma" content="no-cache">
<meta http-equiv="expires" content="-1">
</head>
<body>
You should now be viewing this STATUS page on an HTTPS connection.
</body>
</html>
Nice.
Remember to pass on any GET or POST parameters if you replace pages that require them.
Yeah good one. that is better.
You can not edit user manager html pages. So you can not use the SSL html code you proposed.
But the hot spot redirect option look ok. Must check that out.
thx
Is there any Firewall MT pro?
Can i do the trick with firewall filter ? Is it possible to check for domain name request and if that the request occurred trigger the address re-write to https?
or something like that, i am not good with firewall in MT.
Any advise?
thx
Here is some documentation describing more on customizing hotspot servlet pages (also applies to v4.x):
Customizing HotSpot: HTTP Servlet Pages
Hope this helps.
no thats not it.
I guess it problem got to do with http server that serves pages of itself and only him can check if the page should be server or its url re-writed or change protocal to https. But we dont’ have control over http serve in MT rb.
At least for now.
thx btw
