Hi Guys
We have recently testing WDS
Intel 2.4GHz Rackmount PC running OS 2.9.11
2 x 100mW Atheros (Disabled, replaced with SR5 two days ago)
2 x SR5 Atheros each MiniPCI radio in it’s own one way PCi adaptor
2 x V.P. Sector antenna, each are seperated vertically by 1M with 6M run of coax 3/4 Heliax
We are testing the change over to WDS and also PPPoE to a radius on the Wireless Router LAN.
We are noticing the are a lot of disconnections in the Wirleless Reg Table on the AP running WDS. This also reflects in the PPPoE connections dropping off the raduis server. Also showing the same affect on normal station clients.
How ever, this is the interesting part we have seen before, the clients (WDS Slave Mode) wireless reg table is saying the link has been up for over 1d. This shows on all customers.
This makes me think something to do with the AP end.
**** We have sent a support file to MikroTik. ****
Here are the Wireless Configurations
2 x SR5 AP Bridge WDS on Sector Antenna OS 2.9.11
/ interface vlan
add name=“vlan10-corebridge” mtu=1496 arp=enabled vlan-id=10 interface=corebridge comment=“” disabled=no
add name=“vlan120-corebridge” mtu=1496 arp=enabled vlan-id=120 interface=corebridge comment=“” disabled=no
add name=“vlan110-corebridge” mtu=1496 arp=enabled vlan-id=110 interface=corebridge comment=“” disabled=no
add name=“vlan156-server” mtu=1496 arp=enabled vlan-id=156 interface=“old broken ethernet” comment=“” disabled=no
add name=“vlan156-corebridge” mtu=1496 arp=enabled vlan-id=1 interface=corebridge comment=“” disabled=no
add name=“vlan10-daves” mtu=1496 arp=enabled vlan-id=10 interface=bbDaves comment=“” disabled=no
add name=“vlan181-PtP-svrwks” mtu=1496 arp=enabled vlan-id=181 interface=corebridge comment=“” disabled=no
/ interface ethernet
set “old broken ethernet” name=“old broken ethernet” mtu=1500 mac-address=00:0A:48:0D:52:7C arp=enabled
disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“”
disabled=no
set serverlan name=“serverlan” mtu=1500 mac-address=00:05:1C:19:FB:15 arp=enabled disable-running-check=yes
auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“” disabled=no
/ interface wireless
set bbDaves name=“bbdaves” mtu=1500 mac-address=00:90:96:43:B2:60 arp=enabled disable-running-check=no
radio-name=“00909643B260” mode=ap-bridge ssid=“bb06” area=“” frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=5800 band=5ghz-turbo scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment=“”
disabled=no
set Hornby name=“Hornby” mtu=1500 mac-address=00:01:B4:02:0B:10 arp=enabled disable-running-check=no
radio-name=“maHornbyRadio” mode=ap-bridge ssid=“ma1” area=“” frequency-mode=superchannel country=no_country_set
antenna-gain=0 frequency=5240 band=5ghz scan-list=default rate-set=configured supported-rates-a/g=6Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=manual-table
wds-mode=dynamic wds-default-bridge=corebridge wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no comment=“” disabled=no
set Linwood name=“Linwood” mtu=1500 mac-address=00:01:B4:02:0B:1A arp=enabled disable-running-check=no
radio-name=“maLinwoodRadio” mode=ap-bridge ssid=“maLinwood1” area=“” frequency-mode=superchannel
country=no_country_set antenna-gain=0 frequency=5200 band=5ghz scan-list=default rate-set=default
supported-rates-a/g=6Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=manual-table
/ interface wireless nstreme
set bbDaves enable-nstreme=no enable-polling=no framer-policy=none framer-limit=3200
set Hornby enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
set Linwood enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
/ interface wireless manual-tx-power-table
set bbDaves manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17
,36Mbps:17,48Mbps:17,54Mbps:17
set Hornby manual-tx-powers=1Mbps:26,2Mbps:26,5.5Mbps:26,11Mbps:26,6Mbps:26,9Mbps:26,12Mbps:26,18Mbps:26,24Mbps:26,36Mbps:2
4,48Mbps:22,54Mbps:21
set Linwood manual-tx-powers=1Mbps:26,2Mbps:26,5.5Mbps:26,11Mbps:26,6Mbps:26,9Mbps:26,12Mbps:26,18Mbps:26,24Mbps:26,36Mbps:
24,48Mbps:22,54Mbps:21
/ interface wireless security-profiles
set default name=“default” mode=none wpa-unicast-ciphers=“” wpa-group-ciphers=“” pre-shared-key=“” static-algo-0=none
static-key-0=“” static-algo-1=none static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none
static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key=“”
radius-mac-authentication=no group-key-update=5m
/ interface wireless wds
/ interface bridge
add name=“vlan10-Management” mtu=1500 arp=enabled stp=yes priority=32600 ageing-time=5m forward-delay=15s
garbage-collection-interval=5s hello-time=2s max-message-age=20s comment=“” disabled=no
add name=“vlan120-PPPoE” mtu=1500 arp=enabled stp=yes priority=32600 ageing-time=5m forward-delay=15s
add name=“corebridge” mtu=1500 arp=enabled stp=yes priority=32600 ageing-time=5m forward-delay=15s
add name=“vlan110-ServerLan” mtu=1500 arp=enabled stp=yes priority=32600 ageing-time=5m forward-delay=15s
add name=“vlan156-yobbo” mtu=1500 arp=enabled stp=yes priority=32700 ageing-time=5m forward-delay=15s
add name=“loopback” mtu=1500 arp=enabled stp=no priority=32768 ageing-time=5m forward-delay=15s
/ interface bridge port
add interface=vlan10-corebridge bridge=vlan10-Management priority=128 path-cost=10 comment=“” disabled=no
add interface=vlan120-corebridge bridge=vlan120-PPPoE priority=128 path-cost=10 comment=“” disabled=no
add interface=vlan110-corebridge bridge=vlan110-ServerLan priority=128 path-cost=10 comment=“” disabled=no
add interface=vlan156-server bridge=vlan156-yobbo priority=128 path-cost=10 comment=“” disabled=yes
add interface=vlan156-corebridge bridge=vlan156-yobbo priority=128 path-cost=10 comment=“” disabled=yes
add interface=vlan10-daves bridge=vlan10-Management priority=128 path-cost=10 comment=“” disabled=no
add interface=serverlan bridge=vlan110-ServerLan priority=128 path-cost=10 comment=“” disabled=no
add interface=“old broken ethernet” bridge=vlan10-Management priority=128 path-cost=10 comment=“” disabled=no
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pppoe-server server
add service-name=“#########” interface=vlan120-PPPoE max-mtu=1476 max-mru=1476 authentication=pap keepalive-timeout=10
one-session-per-host=yes max-sessions=0 default-profile=unlimited disabled=no
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2 keepalive-timeout=30
Client - SR5 WDS Slave RIC/522 OS 2.9.11 (An very good antenna and radio intergration with excellant gain on the RF)
set Uplink name=“Uplink” mtu=1500 mac-address=00:15:6D:10:11:84 arp=enabled disable-running-check=no radio-name=“Brighton”
mode=wds-slave ssid=“maLinwood1” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=5260 band=5ghz scan-list=default rate-set=configured supported-rates-a/g=6Mbps basic-rates-a/g=6Mbps
max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=corebridge wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes
disabled=no
set Uplink enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
set Uplink manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:1
add name=“mac on” mode=none wpa-unicast-ciphers=tkip wpa-group-ciphers=tkip pre-shared-key=“” static-algo-0=none
radius-mac-authentication=yes group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no filter-mac=00:00:00:00:00:00 ssid-all=no frames-per-second=25
/ interface wireless access-list
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name=“” file-limit=10
streaming-enabled=no streaming-server=0.0.0.0 streaming-max-rate=0
I do not recall seeing this problem noted in the forum before, is there anyone else out there that has had the some problem. Very confusing for us.
There is also a lot of deauth comming through in the log, have see this was undate in the OS in Ver 2.9.8.
21:30:13 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (6 events suppressed)
21:30:18 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (9 events suppressed)
21:30:23 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (9 events suppressed)
21:30:25 wireless,info Linwood: disconnected 00:15:6D:10:11:84, no beacons
21:30:29 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (9 events suppressed)
21:30:31 wireless,info Linwood: 00:15:6D:10:11:84 connected, is AP, wants WDS
21:30:33 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (6 events suppressed)
21:30:39 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (11 events suppressed)
21:30:43 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (5 events suppressed)
21:30:48 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (9 events suppressed)
21:30:53 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (10 events suppressed)
21:30:58 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (16 events suppressed)
21:31:03 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (10 events suppressed)
21:31:08 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (11 events suppressed)
21:31:13 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (8 events suppressed)
21:31:19 wireless,info Linwood: data from unknown device 00:01:B4:02:0B:21, sent deauth (10 events suppressed)
Is this to be ignored?
Please let me know if there is any other congifuration settings you would like to see.
I look forward to anyones comments.
