Ap Issues
have upgrade our system to 433 series with 3 by r52h pci cards per router and are having all sorts of issues where the clients connect for awhile the disconnect and then reconnect. have upgrade os and firmware that does nor help can anybody help with this problem.
Thks
Brian
Didn’t give us much to work with here. I would check
/log (for any details about the reason for the disconnects)
/int wireless registration-table (for client signal strengths)
/int wireless monitor (for channel crowding)
/int wireless scan (for any APs on the same/close frequency nearby)
If you don’t find a satisfactory answer there, then you may want to include in your next post; the antennas are you using and how they are arranged, and the frequencies are you using.
