APC UPS
Hello
Will any APC ups report to a rb532 the power has gone off or just one with smart or whatever its called
only APC Smart protocol is supported:
http://www.mikrotik.com/testdocs/ros/2.9/system/ups.php
that’s why it’s called smart.
The cheaper APC Back-UPS models would be nice to have support for. It seems silly to not support them - not every situation calls for an expensive Smart-UPS product!
I agree. But I guess implementing support for them is low on the priority list for development.
It seems like a Back-ups would be more beneficial to support than a smart-ups. Back-ups are probably more often deployed for small sites like we’d have an RB at.
The protocol is simpler, as smart-ups has things like temperature, charge, capacity, alert, voltage, relay contacts, and other variables for monitoring. Back-ups is probably just power status.
I use smartups at my datacenter, but don’t monitor them with MTOS, since there is no reason for an extended power outage with the autostart generator.
I thought that it was not, but I have one hooked up right now! I assumed from the lack of confirmation, and no mentions in the manual of Back-UPS that it was not supported. I am not certain, but I thought I also read somewhere that “Only Smart-UPS” is supported.
Back-UPS WORKS, but I cannot say weather it is officially supported. That is up to a staff member to confirm.
This is on ROS 2.9.38, x86 PC with Intel i815 chipset motherboard.
However, I have a “Back-UPS ES 500 FW:2.e2.D USB FW:e2” as identified by ROS working right now.
Back-UPS XS 1100CI-RS WORKS!!!
951G-2HnD 6.10
i have following problem:
RB751 + APC UPS with USB works,
when i take this working ups and connect to RB2011 or RB951 IT DOESNT WORKS AND RB SOMETIMES REBOOTS???
solution?
Here is a RB2011 running v6.12.
I was able to monitor several APC Back-UPS XS-1500G units and an older BX1500G unit. I powered all six APC 1500G UPS's up on the same power strip and moved the USB cable from one to the next.
[admin@TEST Router] > sys resou prin
uptime: 41m13s
version: 6.12
build-time: Apr/14/2014 09:27:45
free-memory: 108.8MiB
total-memory: 128.0MiB
cpu: MIPS 74Kc V4.12
cpu-count: 1
cpu-frequency: 600MHz
cpu-load: 4%
free-hdd-space: 110.7MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 68
write-sect-total: 6461
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB2011UiAS-2HnD
platform: MikroTik
[admin@TEST Router] > sys ups prin
0 name="ups1" port=usbhid1 offline-time=5m min-runtime=5m
alarm-setting=immediate model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8"
serial="4B1345P23018" manufacture-date="2013-11-07"
nominal-battery-voltage=24V
serial="4B1336P39058" manufacture-date="2013-09-06"
serial="4B1345P23098" manufacture-date="2013-11-07"
serial="4B1318P38382" manufacture-date="2013-05-04"
serial="4B1345P23088" manufacture-date="2013-11-07"
alarm-setting=immediate model="Back-UPS BX1500G FW:866.L5 .D USB FW:L5"
serial="3B1106X26340" manufacture-date="2011-02-04"
[admin@TEST Router] /system ups> mon 0
on-line: yes
on-battery: no
rtc-running: no
runtime-left: 17m15s
battery-charge: 100%
battery-voltage: 27.16V
line-voltage: 125V
load: 36%
replace-battery: no
smart-boost: no
smart-trim: no
overload: no
low-battery: no
-- [Q quit|D dump|C-z pause]
This same RB2011 TEST Router will NOT monitor the following other APC UPS's I have laying around:
APC Back-UPS ES-500
APC Back-UPS ES-550
APC Back-UPS ES-600G
Here's the interesting part.
A RB493G with the simple USB power jumper modification can monitor all the aforementioned APC UPS's !!!
[admin@Test2 Router] > sys reso prin
uptime: 12m19s
version: 5.25
free-memory: 244248KiB
total-memory: 257108KiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 680MHz
cpu-load: 2%
free-hdd-space: 79648KiB
total-hdd-space: 126976KiB
write-sect-since-reboot: 5568
write-sect-total: 36885
bad-blocks: 0%
board-name: RB493G
platform: MikroTik
[admin@Test2 Router] > sys ups prin
0 name="ups1" port=usb1 offline-time=5m min-runtime=5m alarm-setting=immediate
model="Back-UPS ES 600G FW:905.W1 .D USB FW:W1" serial="4B1311P39220"
manufacture-date="2013-03-15" nominal-battery-voltage=12V
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1318P38382"
manufacture-date="2013-05-04" nominal-battery-voltage=24V
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1345P23088"
manufacture-date="2013-11-07" nominal-battery-voltage=24V
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1345P23098"
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1336P39058"
manufacture-date="2013-09-06" nominal-battery-voltage=24V
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1345P23018"
model="Back-UPS BX1500G FW:866.L5 .D USB FW:L5" serial="3B1106X26340"
manufacture-date="2011-02-04" nominal-battery-voltage=24V
model="Back-UPS ES 500 FW:2.e2.D USB FW:e2" serial="AB0312140479"
manufacture-date="2003-03-17" nominal-battery-voltage=12V
model="Back-UPS ES 550 FW:843.K2 .D USB FW:K2" serial="3B1135X25856"
manufacture-date="2011-08-27" nominal-battery-voltage=12V
Well, maybe the RB493G can monitor ALL nine of these APC UPS's because it's running v5.25? Let's upgrade this RB493G to v6.12 and see if it still can monitor all these different APC UPS's...
How about that! A RB493G with USB power jumper modification running v6.12 is able to monitor ALL of these different APC UPS's!!!!
uptime: 2m13s
version: 6.12
free-memory: 227.0MiB
total-memory: 256.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-load: 0%
free-hdd-space: 110.3MiB
total-hdd-space: 127.8MiB
write-sect-since-reboot: 959
write-sect-total: 32276
bad-blocks: 0%
board-name: RB493G
platform: MikroTik
0 name="ups1" port=usbhid1 offline-time=5m min-runtime=5m alarm-setting=immediate
That's not all....it gets even more interesting when we start testing CCR1036-12G-4S routers. The first CCR1036-12G-4S is able to monitor ALL nine of the different APC UPS's I have here to test! Yay!
[admin@MikroTik] > sys reso prin
uptime: 2m57s
version: 6.12
free-memory: 3790.1MiB
total-memory: 3969.0MiB
cpu: tilegx
cpu-count: 36
cpu-frequency: 1200MHz
cpu-load: 0%
free-hdd-space: 905.5MiB
total-hdd-space: 1024.0MiB
architecture-name: tile
board-name: CCR1036-12G-4S
platform: MikroTik
[admin@MikroTik] > sys ups prin
model="Back-UPS BX1500G FW:866.L5 .D USB FW:L5" serial="3B1106X26340" manufacture-date="2011-02-04"
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1318P38382" manufacture-date="2013-05-04"
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1345P23098" manufacture-date="2013-11-07"
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1345P23088" manufacture-date="2013-11-07"
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1336P39058" manufacture-date="2013-09-06"
model="Back-UPS XS 1500G FW:866.L8 .D USB FW:L8" serial="4B1345P23018" manufacture-date="2013-11-07"
model="Back-UPS ES 500 FW:2.e2.D USB FW:e2" serial="AB0312140479" manufacture-date="2003-03-17"
model="Back-UPS ES 550 FW:843.K2 .D USB FW:K2" serial="3B1135X25856" manufacture-date="2011-08-27"
model="Back-UPS ES 600G FW:905.W1 .D USB FW:W1" serial="4B1311P39220" manufacture-date="2013-03-15"
[admin@MikroTik] >
The second CCR1036-12G-4S router I tested could only monitor one of the nine APC UPS's ....Booooo!!!!
[admin@CCR1036 Test2 Router] > sys reso prin
uptime: 6m51s
version: 6.12
free-memory: 3767.0MiB
cpu: tilegx
cpu-count: 36
cpu-load: 0%
free-hdd-space: 902.4MiB
platform: MikroTik
[admin@CCR1036 Test2 Router] > sys ups prin
[admin@CCR1036 Test2 Router] > sys resou usb prin
DEVICE VENDOR NAME SPEED
0 2:1 Linux 3.3.5 ohci_hcd Tile-Gx OHCI 12 Mbps
1 2:5 APC Back-UPS ES 600G FW:905.W1 ... 1.5 Mbps
2 1:1 Linux 3.3.5 ehci_hcd Tile-Gx EHCI 480 Mbps
Here is the USB print from the first CCR1036 that can monitor all nine UPS's:
[admin@MikroTik] > sys reso usb prin
1 2:2 APC Back-UPS ES 600G F... 1.5 Mbps
1 1:1 Linux 3.3.5 ehci_hcd Tile-Gx EHCI 480 Mbps
2 2:3 American Power Conversion Back-UPS XS 1500G FW:866.L... 12 Mbps
[admin@MikroTik] >
What do the guru's at MikroTik think the issue is?
(1) Why does a RB2011 only see the 1500G UPS's and the RB493G sees all nine UPS's?
(2) Why does one CCR1036 see all nine UPS's, but a second CCR1036 only sees the 600G and no other UPS's?
Thanks for those that took time to read this!
Brad
USB UPS support on new RB sux,
if u have old RB751, RB411u or sg like that, ups shoud work well.
some fix for USB UPS → RB2011,911 … !!!
So is there support for the APC UPS or not?
The 10 topics with this issue and silence :confused:
Hello guys,
Any news on support of Backup-UPS ES 550/700 ?
