Hello erlinden
Thank you for attention to my problem.
yeap, I’m specialy use diffirent SSID.
My notes.
In 5Ghz - both Iphone disconected and connected automaticly when device in standby mode. when devices is active - there is no problem at all.
Try test how it’s works in 2Ghz AX - Iphone disconected in all end with message
20:16:42 wireless,info 16:3F:4E:XX:XX:XX@wifi2 connected, signal strength -57
20:16:46 dhcp,info defconf deassigned 192.168.22.10 for 16:3F:4E:XX:XX:XX
20:16:47 dhcp,info defconf assigned 192.168.22.10 for 16:3F:4E:XX:XX:XX
20:25:16 wireless,info 16:3F:4E:05:76:6D@wifi2 disconnected, connection lost, signal strength -51
2Ghz N-only WPA2/WPA3
20:30:15 wireless,info 16:3F:4E:XX:XX:XX@wifi2 connected, signal strength -61
20:30:20 dhcp,info defconf deassigned 192.168.22.10 for 16:3F::XX:XX:XX
20:30:21 dhcp,info defconf assigned 192.168.22.10 for 16:3F::XX:XX:XX
20:35:59 wireless,info 16:3F:4E:XX:XX:XX@wifi2 disconnected, connection lost, signal strength -52
UDDATE
Test 5Ghz AC - not help.
Both phones disconnect from Wi-Fi when they fall asleep in standby mode. I don’t understand over what period this happens. And in standby mode it is on LTE. When you pick up the phone it tries to connect to Wi-Fi and I notice this. When the phone is active, Wi-Fi does not disconnect. Perhaps the reason is that Mikrotik does not track when the device “falls asleep in standby mode”.
Here is my config
[admin@MikroTik_hAP ax^2] > export
# 2024-02-21 20:40:26 by RouterOS 7.13.5
# software id = XXXX-XXXX
# model = C52iG-5HaxD2HaxD
# serial number = HFXXXXXXXXX
add admin-mac=78:9A:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface wifi
set [ find default-name=wifi2 ] channel.band=2ghz-n .skip-dfs-channels=all configuration.country=Ukraine .mode=ap .ssid=MikroTik disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk .connect-priority=0 .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi security
add authentication-types=wpa3-psk connect-priority=0 disabled=no name=MySec
/interface wifi configuration
add channel.skip-dfs-channels=10min-cac country=Ukraine disabled=no name=tp-link200 security=MySec security.ft=yes .ft-over-ds=yes ssid=tp-link200
/interface wifi
set [ find default-name=wifi1 ] configuration=tp-link200 configuration.mode=ap disabled=no name=wifi5
add name=dhcp ranges=192.168.22.10-192.168.22.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 path-cost=10
add bridge=bridge interface=wifi5
add address=192.168.22.1/24 comment=defconf interface=bridge network=192.168.22.0
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
add address=192.168.22.0/24 comment=defconf dns-server=192.168.22.1 gateway=192.168.22.1 netmask=24
set allow-remote-requests=yes use-doh-server=https://1.1.1.1/dns-query verify-doh-cert=yes
/ip dns static
add address=192.168.22.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 dhcp-client
add disabled=yes interface=ether1 pool-name=test-ipv6 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Kiev
/system identity
set name="MikroTik_hAP ax^2"
/system note
set show-at-login=no
/tool graphing interface
add interface=ether1
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
