I seem to get the correct IPs and my dhcp leases seem to match the VLAN structure, but I wanted to ask if there is a problem I'm not aware of. Thanks in advance. RB5009 is core router, CRS328 is the switch+POE.
add admin-mac=redacted auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan10-main vlan-id=10
add interface=bridge name=vlan20-iot vlan-id=20
add interface=bridge name=vlan30-guest vlan-id=30
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool10 ranges=192.168.10.100-192.168.10.250
add name=pool20 ranges=192.168.20.100-192.168.20.250
add name=pool30 ranges=192.168.30.100-192.168.30.250
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=pool10 interface=vlan10-main name=dhcp10
add address-pool=pool20 interface=vlan20-iot name=dhcp20
add address-pool=pool30 interface=vlan30-guest name=dhcp30
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface bridge vlan
add bridge=bridge tagged=bridge,sfp-sfpplus1 vlan-ids=10
add bridge=bridge tagged=bridge,sfp-sfpplus1 vlan-ids=20
add bridge=bridge tagged=bridge,sfp-sfpplus1 vlan-ids=30
add interface=vlan10-main list=LAN
add interface=vlan20-iot list=LAN
add interface=vlan30-guest list=LAN
192.168.88.0
add address=192.168.10.1/24 interface=vlan10-main network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20-iot network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30-guest network=192.168.30.0
/ip dhcp-client
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=192.168.30.1 gateway=192.168.30.1
192.168.88.1
set allow-remote-requests=yes servers=192.168.10.249
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 \
in-interface=lo src-address=127.0.0.1
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
in-interface-list=WAN
"VLAN 10 can initiate talk to any local subnet" in-interface=vlan10-main
"Allow all subnets to query Pi-hole for DNS (UDP)" dst-address=\
192.168.10.249 dst-port=53 protocol=udp
"Allow all subnets to query Pi-hole for DNS (TCP)" dst-address=\
192.168.10.249 dst-port=53 protocol=tcp
"Isolate VLAN 30 entirely from local subnets (Internet Only)" \
dst-address=192.168.0.0/16 in-interface=vlan30-guest
"Allow Emergency Backdoor to access all VLANs" src-address=\
192.168.88.0/24
add action=drop chain=forward comment="Drop all traffic aimed at VLAN 10" \
out-interface=vlan10-main
add action=dst-nat chain=dstnat comment="Force DNS to Pi-hole (UDP)" \
dst-port=53 protocol=udp src-address=!192.168.10.249 to-addresses=\
192.168.10.249
add action=dst-nat chain=dstnat comment="Force DNS to Pi-hole (TCP)" \
dst-port=53 protocol=tcp src-address=!192.168.10.249 to-addresses=\
192.168.10.249
/ip service
set ftp disabled=yes
set ssh disabled=yes
set telnet disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Chicago
/system identity
set name=RB5009.CoreRouter
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
CRS328
vlan-filtering=yes
/interface vlan
add interface=bridge name=mgmt-vlan10 vlan-id=10
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether4 pvid=20
admit-only-untagged-and-priority-tagged interface=ether5 pvid=10
admit-only-untagged-and-priority-tagged interface=ether9 pvid=20
admit-only-untagged-and-priority-tagged interface=ether10 pvid=10
admit-only-untagged-and-priority-tagged interface=ether11 pvid=20
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
admit-only-untagged-and-priority-tagged interface=ether22 pvid=30
add bridge=bridge comment=defconf interface=ether23 pvid=20
admit-only-untagged-and-priority-tagged interface=ether24 pvid=10
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether1,ether2,ether3 untagged=\
ether5,ether10,ether24 vlan-ids=10
add bridge=bridge tagged=sfp-sfpplus1,ether1,ether2,ether3 untagged=\
ether4,ether9,ether11,ether23 vlan-ids=20
add bridge=bridge tagged=sfp-sfpplus1,ether1,ether2,ether3 untagged=ether22 \
vlan-ids=30
add address=192.168.10.2/24 interface=mgmt-vlan10 network=192.168.10.0
/ip service
/system identity
set name=CRS328.MainPoESwitch
/system routerboard settings
set enter-setup-on=delete-key
