Array of mac addresses? is it possible ???
I want create array of all mac addresses from firewall. If I use array for processing, script could be faster.
How can I do it?
Following script is only my suggestion, but it doesnt work.
variable “pole” should be array.
:local pole                # I want variable "pole" to be an array of mac addresses.
:local filtermac
:local i
:local j
    :local fpravidla [/ip firewall filter find]
    :set i 0
    :foreach j in $fpravidla do={
        :set filtermac [/ip firewall filter get $j value-name=src-mac-address]
        :set i ($i+1)
        :set pole[$i] $filtermac      # how can I write this?
The syntax for adding elements to an array can be found here:
http://wiki.mikrotik.com/wiki/Manual:Scripting#Concatenation_Operators
This script loops through the filter rules and adds the src-mac addresses to the array. Tested in RouterOS v5.7.
	:local pole;
	:foreach j in=[/ip firewall filter find] do={
		:set pole ( $pole , [/ip firewall filter get $j src-mac-address]);
