i’m interested WHY and WHEN,because as soon as pressed “Make Static” by default is enabled
*) winbox - added “allow-dual-stack-queue” setting to “IP / DHCP Server / Leases” menu;
so that same client can use both ipv4 and ipv6 addresses and get classified under same dynamic simple queue.
okay, i got activated allow-dual-stack-queue on my clients and im using ipv4, but nothing happens in QoS side.
so you have rate-limit specified? in leases
you have both ipv4 and ipv6 dhcp servers running on router?
you have client that got both ipv4 and ipv6 address?
then you should see dynamic simple queue with target both ipv4 and ipv6 address in the same simple queue, not separately as before.
I know what you mean.
Thanks a lot ![]()
