[Ask]Applying best Bandwidth Management with ext-Proxy
Greetings,
I only have 2 Question.
  1. What happened with dst-nat-ed packets and how or where should i mark the packet so I can apply bandwidth management to it.
  2. Which is better to apply in a shared wan connection, PCQ queue tree or regular queue tree? since the received bandwidth is always unstable(up-to)
Now the explaination:
I’m trying to find the best bandwidth management to this topology. Appology if i use explained topology not graphical to better explain the situation.
  1. Users will connect to a switch. the network is 192.168.1.0/24
  2. Switch is connected to a port in mikrotik RB750 with 192.168.1.1/24 address in mikrotik
  3. A Linux based proxy server with 192.168.2.2/24 ip address is connected to another port in mikrotik with 192.168.2.1/24 address
  4. Another port in mikrotik with ip address of 192.168.10.254 is connected to an ADSL modem using 192.168.10.1/24 address
  5. ADSL modem is connected to internet using PPPoE connection to the ISP
    add address=192.168.2.1/24 disabled=no interface=04-Proxy network=192.168.2.0
    add address=192.168.10.254/24 disabled=no interface=05-Speedy network=192.168.10.0
    add address=192.168.1.1/24 disabled=no interface=02-LAN network=192.168.1.0
    add address=192.168.3.1/24 disabled=no interface=01-None network=192.168.3.0/ip firewall nat
    add action=masquerade chain=srcnat comment=“” disabled=no out-interface=
    05-Speedy
    add action=dst-nat chain=dstnat comment=“Proxy for Local redirection” disabled=no dst-port=80,8080,3128 in-interface=
    02-LAN protocol=tcp to-addresses=192.168.2.2 to-ports=3128
    add action=dst-nat chain=dstnat comment=“Redirect DNS Request from LAN” disabled=no dst-port=53 protocol=udp to-ports=53
    add action=redirect chain=dstnat comment=“Redirect DNS Request from squid” disabled=no dst-port=53 in-interface=04-Proxy
    protocol=udp to-ports=53above are my ip address and nat
    as my question above, i’m having trouble to create suitable queue for 12 users only when the http requests are dst-nated to proxy. I have marked the hit packet from proxy with DSCP 12. where should i put marking for the http requests that are automatically routed to proxy, and how to limit the bandwidth so even proxy request to the server also limited. because even tho i can limit the MISS packet to the users, the proxy request to the internet is still unlimited, so the other service such as game connection is disrupted. Especially, how can i best manage the upload request that has been passed through proxy so that it is also properly managed?
Thankyou so much for replies.
mark packets in forward, one mark for upload to 192.168.2.2 port 3128 protocol tcp, one mark for download from 192.168.2.2 port 3128 protocol tcp
after you create two pcq queues (one for upload, one for download from proxy), traffic shaping should be done in global-out for upload and download from proxy.
