i want to ask what is load-balancing…? i’ve been searching the internet for load-balancing in mikrotik and i found very diffrent info about load-balancing. is it like this =
a. when router 1 down and then router 2 will take charge (VRRP) or
b. ISP1:256KBPS + ISP2:512KBPS = 768KBPS
need help pliss from forum guru or anyone…?
i’m very noob in load-balancing and i’m sorry if my english is bad
for simple one, use ECMP, gateway check, you can find it in ip/route
