Dear All Master,
Need help, how blocking packet or software connectify from user, cause all rule firewall can’t working if user connecting from cnnectify.
Thanks,
Wait for solution
Dear All Master,
Thanks,
Wait for solution
u need to know how that software connecting to wifi.
exp they use specify port or not, if yes u can block that port
other than that is difficult to block software
Sir,
User connect to router normally with LAN Cable, and WiFi will be hotspot for another peripheral for connecting, problem is filter rule can’t working if user connect to hotspot connectify, basically at LAN Cable user can’t browsing all access.
so it very difficult to checking port, from another tutorial can create modify TTL (Time to Life) at filter rule mangle, but after testing still not effected.
Need help if have any idea for that.
