[ASK] Script for user based on data usage
Hai guys, I want to make policy in my network. So let say we give user 75Gb of quota and we want to make sure if user reach 50% of their internet data usage the speed will drop to 80% of their current max limit and 75% if they reach 80% internet data usage. I know the idea behind these scenario but I’m difficult to implement it via mikrotik scripting since I’m not play so much with script. Is anybody know how to write script for this scenario? Or share it here if you already know it.
Sorry for my bad english.
Sent from my Redmi 5 using Tapatalk
create three user profiles according to speed, then run this script using the scheduler
:foreach i in=[/ip hotspot active find]  do={
/ip hotspot active remove $i
/ip hotspot user {
    :local limitedProfile "5m"
    :local limitedSlowProfile "fup1"
    :local trafLimit 1073741824
    :local userList [find profile=$limitedProfile]
    :foreach user in=$userList do={
        :local traf ([get $user bytes-in] + [get $user bytes-out])
        :put ("User (" . [get $user name] . ") traf: " . $traf)
        :if ($traf > $trafLimit) do={
            set $user profile=$limitedSlowProfile
            :put ("User (" . [get $user name] . ") reached the traf limit")
            :log warning ("User (" . [get $user name] . ") reached the traf limit")
 /ip hotspot user {
    :local limitedProfile "fup1"
    :local limitedSlowProfile "fup2"
    :local trafLimit 1610612736
http://forum.mikrotik.com/t/how-can-i-limit-users-according-to-amount-of-download/98305/33
Has anyone had any success using the above script?
Have tried on two routers, one RB5009UG+S+ running v7.7 and the other a RB750Gr3 running v6.49.7, without success.
Is it compatible with those versions of RouterOS?
jcbhnz
