Associate with two 5ghz networks at the same time in station mode(client) with SXTsq 5 ac
I’d like to connect the SXTsq 5 AC to two 5ghz networks simultaneously. I can connect the default wlan1 interface to a 5ghz network just fine, but if I try to create another virtual interface in station mode and use wlan1 as the master interface. It says that “Couldn’t add new Interface - license level does not allow virtual AP (6).” It technically has Level 3 license level… which should be okay as a client, but can it not allow multiple network connections on the same radio?
You can’t connect to two networks as a client regardless of version.
If you had a board with 2 of the 5ghz chips then yes but certainly not through virtual. It simply can’t do what you are asking.
Thanks for the clarification. I figured it would be most likely the case that one radio can only associate with one network. I was thinking the Virtual AP feature where you can act as both a station and AP in order to broadcast a different network (resharing hotel wifi etc) might allow for something like connecting to two networks.
