Hi to all,
this is my situation:
- 4 vdsl 100/30Mb provided by 4 different internet suppliers with stock routers( I cannot change them) and I have disabled firewall AGL parameters and all other security options
- of these 3 VDSL only one supplier gives me a mask of public IPs, the other 2 have only 1 static IP so everything is behind NAT
- these 4 routers are connected to the 4 wan interfaces of a CCR1009-7G-1C-1S+ cloud router like this
eth1 is connected to provider 1 vdsl router 192.168.30.1 - eth1 mikrotik address 192.168.30.2/24 (main:fibra-telecom)
eth2 is connected to provider 2 vdsl router 192.168.130.1 - eth2 mikrotik address 192.168.130.2/24 (fibra-backup)
eth3 is connected to provider 3 vdsl router 192.168.230.1 - eth2 mikrotik address 109.234.60.236/29 (this is the public one: fibra-ehiweb)
eth4 is connected to provider 4 vdsl router 192.168.231.1 - eth2 mikrotik address 192.168.231.2/24 (TIM4G)
eth7 is my local lan 192.168.25.0/24
eth1 is the main interface with the highest priority, anything else is selected trough mangle rules and mark routing to a specific IP (in example mail server is on fibra-backup with ip 192.168.25.5, and asterisk is on fibra-ehiweb with ip 192.168.25.200)
so.. My asterisk Freepbx is hosted on a local HA cluster and is receving the public IP through a mangle rule, this is working very well and stable.
What I want to do is an internet backup in case of failure simply changing the freepbx magle rule from the provider 3 to any other provider.
I know that double NAt is always a problem with freepbx, but my sip trunks uses chan_pjsip driver and there are a lot of rules that must help me to fix the problem. But I cannot figure out of this, maybe is something missing in my mikrotik to makes things works. The strange thing is that using the main 192.168.30.1 as mark route sometimes works but is very unstable, no way with the other providers.
This is my configuration I hope to find a solution, cause I think that is very interesting to have a backup for a VOIP production environment.
# mar/12/2018 10:36:24 by RouterOS 6.36.4
# software id = BXAR-5YJB
set [ find default-name=ether1 ] name="ether1-fibra telecom"
set [ find default-name=ether2 ] name="ether2-fibra backup"
set [ find default-name=ether3 ] name="ether3-fibra ehiweb"
set [ find default-name=ether4 ] name=ether4-TIM4G
set [ find default-name=ether7 ] arp=proxy-arp name="ether7-local lan"
/interface gre
add allow-fast-path=no disabled=yes !keepalive local-address=192.168.30.2 \
name=anek remote-address=aaa.aaa.aaa.aaa
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc,3des pfs-group=none
add enc-algorithms=3des name=proposal1 pfs-group=none
add auth-algorithms=md5 enc-algorithms=des name=superfast pfs-group=none
add enc-algorithms=3des name=proposal2 pfs-group=none
add name=dhcp_pool1 ranges=192.168.25.201-192.168.25.250
add address-pool=dhcp_pool1 disabled=no interface="ether7-local lan" name=\
dhcp1
/interface l2tp-server server
set enabled=yes
add address=192.168.25.62/24 interface="ether7-local lan" network=\
192.168.25.0
add address=192.168.233.54/30 interface=anek network=192.168.233.52
add address=192.168.30.2/25 interface="ether1-fibra telecom" network=\
192.168.30.0
add address=10.1.2.1/30 network=10.1.2.0
add address=172.0.0.1/24 comment="lan per cisco" interface=ether6 network=\
172.0.0.0
add address=192.168.130.2/24 interface="ether2-fibra backup" network=\
192.168.130.0
add address=bbb.bbb.bbb.bbb/29 interface="ether3-fibra ehiweb" network=\
ccc.ccc.ccc.ccc
add address=192.168.230.2/24 interface="ether3-fibra ehiweb" network=\
192.168.230.0
add address=192.168.231.2/24 interface=ether4-TIM4G network=192.168.231.0
add address=ddd.ddd.ddd.ddd/29 disabled=yes interface="ether3-fibra ehiweb" \
network=ccc.ccc.ccc.ccc
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid interface=ether5
/ip dhcp-server lease
add block-access=yes mac-address=2A:BD:6F:6B:00:B3
add address=192.168.25.0/24 dns-server=192.168.25.62 gateway=192.168.25.62 \
netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.25.5 name=mail.anekitalia.com
add address=192.168.25.126 name=crm.anekitalia.com
/ip firewall address-list
add address=eee.eee.eee.eee list=toplevel
add address=192.168.27.0/24 list=venezia
add address=ddd.ddd.ddd.ddd list=vtecrm
add action=drop chain=forward connection-state=invalid,new disabled=yes \
in-interface="ether2-fibra backup" src-address=0.0.0.0/0
add action=accept chain=forward in-interface="ether1-fibra telecom" protocol=\
tcp src-port=1723
gre
add action=accept chain=input dst-port=500 protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=1701 protocol=udp
add action=accept chain=input protocol=ipsec-ah
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input in-interface="ether1-fibra telecom" \
src-address=79.58.72.190
src-address=93.42.154.226
add action=accept chain=input src-address=aaa.aaa.aaa.aaa
add action=accept chain=input src-address=212.205.152.194
add action=accept chain=input src-address=78.134.7.223
add action=accept chain=input src-address=8.8.8.8
add action=accept chain=input src-address=8.8.4.4
add action=accept chain=input src-address=83.211.227.21
add action=drop chain=input in-interface="ether1-fibra telecom"
add action=drop chain=input in-interface="ether2-fibra backup"
add action=drop chain=input in-interface="ether3-fibra ehiweb"
add action=drop chain=input in-interface=ether4-TIM4G
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=fibra-backup \
passthrough=yes src-address=192.168.25.208
add action=mark-routing chain=prerouting dst-address=!192.168.26.0/24 \
dst-address-list=!venezia new-routing-mark=fibra-ehiweb passthrough=yes \
src-address=192.168.25.200
dst-address-list=!venezia new-routing-mark=fibra-backup passthrough=yes \
src-address=192.168.25.5
passthrough=yes src-address=192.168.25.75
add action=accept chain=prerouting
add action=masquerade chain=srcnat disabled=yes src-address=192.168.26.0/24
add action=src-nat chain=srcnat disabled=yes out-interface=\
"ether3-fibra ehiweb" src-address=192.168.25.47 to-addresses=\
ddd.ddd.ddd.ddd
add action=dst-nat chain=dstnat disabled=yes dst-address=ddd.ddd.ddd.ddd \
in-interface="ether3-fibra ehiweb" to-addresses=192.168.25.6
add action=masquerade chain=srcnat dst-address=10.1.1.0/24
add action=masquerade chain=srcnat dst-address=10.1.150.128
add action=masquerade chain=srcnat comment="Fibra Telecom main" \
out-interface="ether1-fibra telecom"
add action=masquerade chain=srcnat out-interface="ether2-fibra backup"
add action=masquerade chain=srcnat comment=eihweb out-interface=\
add action=masquerade chain=srcnat out-interface=ether4-TIM4G
add action=masquerade chain=srcnat disabled=yes src-address=192.168.25.192/27
add action=dst-nat chain=dstnat dst-port=22 in-interface=\
"ether1-fibra telecom" protocol=tcp src-address-list=vtecrm to-addresses=\
192.168.25.126 to-ports=22
add action=dst-nat chain=dstnat dst-port=80 in-interface=\
192.168.25.126 to-ports=80
add action=dst-nat chain=dstnat dst-port=8080 in-interface=\
192.168.25.126 to-ports=8080
add action=dst-nat chain=dstnat dst-port=1194 in-interface=\
"ether1-fibra telecom" protocol=udp to-addresses=192.168.25.7 to-ports=\
1194
add action=dst-nat chain=dstnat dst-port=1195 in-interface=\
"ether1-fibra telecom" protocol=udp to-addresses=192.168.25.76 to-ports=\
1195
add action=dst-nat chain=dstnat dst-port=8070 protocol=tcp to-addresses=\
192.168.25.109 to-ports=80
add action=dst-nat chain=dstnat dst-port=443 in-interface=\
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.5 to-ports=443
add action=dst-nat chain=dstnat dst-port=110 in-interface=\
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.5 to-ports=110
add action=dst-nat chain=dstnat dst-port=995 in-interface=\
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.5 to-ports=995
add action=dst-nat chain=dstnat dst-port=143 in-interface=\
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.5 to-ports=143
add action=dst-nat chain=dstnat dst-port=993 in-interface=\
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.5 to-ports=993
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.5 to-ports=80
add action=dst-nat chain=dstnat disabled=yes dst-port=5060 in-interface=\
"ether2-fibra backup" protocol=udp to-addresses=192.168.25.6 to-ports=\
5060
add action=dst-nat chain=dstnat disabled=yes dst-port=5061 in-interface=\
5061
add action=dst-nat chain=dstnat disabled=yes dst-port=5160 in-interface=\
5160
add action=dst-nat chain=dstnat disabled=yes dst-port=5151 in-interface=\
5161
add action=dst-nat chain=dstnat disabled=yes dst-port=5065 in-interface=\
5065
add action=dst-nat chain=dstnat disabled=yes dst-port=10000-20000 \
in-interface="ether2-fibra backup" protocol=udp to-addresses=192.168.25.6 \
to-ports=10000-20000
add action=dst-nat chain=dstnat dst-port=25 in-interface=\
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.75 to-ports=25
add action=dst-nat chain=dstnat dst-port=587 in-interface=\
"ether2-fibra backup" protocol=tcp to-addresses=192.168.25.5 to-ports=587
add action=accept chain=srcnat disabled=yes
/ip firewall service-port
set sip disabled=yes
add distance=1 gateway=eee.eee.eee.eee routing-mark=fibra-ehiweb
add distance=3 gateway=192.168.130.1 routing-mark=fibra-backup
add distance=100 gateway=192.168.231.1 routing-mark=TIM4G
add distance=1 gateway=192.168.30.1
add distance=2 gateway=192.168.130.1
add distance=4 gateway=192.168.230.1
add distance=1 dst-address=10.1.1.0/24 gateway=192.168.25.106
add distance=1 dst-address=10.1.150.128/32 gateway=192.168.25.106
add distance=1 dst-address=10.1.150.201/32 gateway=192.168.25.106
add distance=1 dst-address=10.250.0.2/32 gateway=192.168.25.106
add distance=1 dst-address=79.58.72.190/32 gateway=192.168.30.1
add distance=1 dst-address=192.168.0.0/24 gateway=192.168.25.106
add distance=1 dst-address=192.168.1.0/24 gateway=192.168.25.106
add distance=1 dst-address=192.168.2.0/24 gateway=192.168.25.106
add distance=1 dst-address=192.168.10.0/24 gateway=192.168.25.106
/ip route rule
add action=lookup-only-in-table disabled=yes table=main
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8089
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set time-interval=hour
/ppp secret
add local-address=1.3.3.1 name=Portoanek password=Portoanek13579 \
remote-address=1.3.3.2 routes="192.168.26.0/24 1.3.3.2 1" service=l2tp
add local-address=1.3.3.3 name=venezia password=venezia13579@ remote-address=\
1.3.3.4 routes="192.168.27.0/24 1.3.3.4 3" service=l2tp
add disabled=yes local-address=10.10.10.210 name=toplevel password=\
toplevelts12@ remote-address=10.10.10.211 routes=\
"192.168.0.0/24 10.10.10.211 210" service=l2tp
/system clock
set time-zone-name=Europe/Rome
/system routerboard settings
set protected-routerboot=disabled
